Get Barcode128 Dimension from Vintasoft
IAmByB
Post by IAmByB » Fri Jan 20, 2017 1:49 pm
I am trying to develop an application in C# / Windows Form with Vintasoft to read a barcode 128 and know the Dimension (min width of narrow black bar).
For this I use the above code, but I do not find any information of the Dimension value behind the informations collected in the infos value obtained from IBarcodeInfo[] infos = reader.ReadBarcodes(barcodeImage);
Is Vintasoft able to find and display this information (1 px, 2px, 3px etc.) ?
Thank you for your help.
Code used is the following :
(lbInfos is a ListBox on my form).
public void ReadBarcodesFromImage(Image barcodeImage)
    lbInfos.Items.Clear();
    // create barcode reader
    // specify that reader must search for Code39, Code39Extended,
    // Code128, SSCC18 and DataMatrix barcodes
    reader.Settings.ScanBarcodeTypes =
        BarcodeType.Code39 |
        BarcodeType.Code128 |
        BarcodeType.DataMatrix;
    reader.Settings.ScanBarcodeSubsets.Add(BarcodeSymbologySubsets.Code39Extended);
    reader.Settings.ScanBarcodeSubsets.Add(BarcodeSymbologySubsets.SSCC18);
    // specify that reader must search for horizontal and vertical barcodes only
    reader.Settings.ScanDirection = ScanDirection.Horizontal | ScanDirection.Vertical;
    // use Automatic Recognition
    reader.Settings.AutomaticRecognition = true;
    // read barcodes from image
    // if barcodes are not detected
    if (infos.Length == 0)
        Console.WriteLine("No barcodes found.");
    // if barcodes are detected
        // get information about extracted barcodes
        Console.WriteLine(string.Format("{0} barcodes found:", infos.Length));
        Console.WriteLine();
        for (int i = 0; i < infos.Length; i++)
            IBarcodeInfo info = infos[i];
            lbInfos.Items.Add(string.Format("[{0}:{1}]", i + 1, info.BarcodeType));
            lbInfos.Items.Add(string.Format("Value:      {0}", info.Value));
            lbInfos.Items.Add(string.Format("Region:     {0}", info.Region));
Re: Get Barcode128 Dimension from Vintasoft
Post by Alex » Fri Jan 20, 2017 2:13 pm
Do you want to get the bar width of the recognized barcode?
IAmByB
Post by IAmByB » Fri Jan 20, 2017 2:39 pm
Yes, I want to get the bar width value of the recognized barcode (I understand it is the MinWidth value I can set in the Vintasoft barcode writer).
Post by Alex » Fri Jan 20, 2017 2:52 pm
IAmByB wrote:Yes, I want to get the bar width value of the recognized barcode (I understand it is the MinWidth value I can set in the Vintasoft barcode writer).
The BarcodeInfo1D.NarrowBarCount property returns the bar count in the recognized barcode:
http://www.vintasoft.com/docs/vsbarcode ... Count.html
The BarcodeInfo1D.NarrowBarSize property returns the bar width in pixels:
http://www.vintasoft.com/docs/vsbarcode ... rSize.html
IAmByB
Post by IAmByB » Fri Jan 20, 2017 6:21 pm
OK, I found the needed information. Thank you !
IAmByB
Post by IAmByB » Mon Jan 23, 2017 2:03 pm
Please can you tell me what is the unit of the NarrowSizeBar value obtained when reading a barcode 128 with Vintasoft ? I assumed that it was in pixels, but I'd like to have a confirmation from your part ?
I try to generate a barcode 128 with a NarrowBar Size of 0,375 millimeters, at a resolution of 72 dpi. For that, I use the following statement :
writer.Settings.SetMinWidth(0.375, UnitOfMeasure.Millimeters);
but when I read the barcode I created, the NarrowBar Size value read by Vintasoft is 4.6.
If the 4.6 value is in pixels, the result in millimeters is (4.6 / 72) x 25.4 = 1.62 mm, which is very different from the 0.375 value I expected.
Can you help me in this point ? Thank you.
Post by Alex » Mon Jan 23, 2017 2:30 pm
Here is a console application that creates Code128 barcode (bar width is set to 2 pixels) and reads Code128 barcode (bar width is 2 pixels) from created image:
using System;
using System.Drawing;
using Vintasoft.Barcode;
using Vintasoft.Barcode.BarcodeInfo;
namespace ConsoleApplication1
    class Program
            BarcodeWriter barcodeWriter = new BarcodeWriter();
            barcodeWriter.Settings.Barcode = BarcodeType.Code128;
            barcodeWriter.Settings.Value = "1234567890";
            barcodeWriter.Settings.Resolution = 72;
            barcodeWriter.Settings.SetMinWidth(0.375, UnitOfMeasure.Millimeters);
            if (barcodeWriter.Settings.MinWidth != 2)
                throw new ApplicationException();
            using (Bitmap bitmap = barcodeWriter.GetBarcodeAsBitmap())
                using (BarcodeReader barcodeReader = new BarcodeReader())
                    barcodeReader.Settings.ScanBarcodeTypes = BarcodeType.Code128;
                    IBarcodeInfo[] infos = barcodeReader.ReadBarcodes(bitmap);
                    if (infos.Length != 1)
                    BarcodeInfo1D info1D = infos[0] as BarcodeInfo1D;
                    if (info1D.NarrowBarSize != 2)
Please try to use this code and let me know if you will have any question or problem.
IAmByB
Post by IAmByB » Tue Jan 24, 2017 1:24 pm
Thank you very much for your code. I tried it and it works perfectly. It helped me to check that my own code is correct.
Can you please tell me what is the measurement unit of the MinWidth value (not the 0.375 value but the 2 value) ?
Thank you again for your help.
Post by Alex » Tue Jan 24, 2017 2:05 pm
IAmByB wrote:Can you please tell me what is the measurement unit of the MinWidth value (not the 0.375 value but the 2 value) ?
The WriterSettings.MinWidth property value is specified in pixels:
http://www.vintasoft.com/docs/vsbarcode ... Width.html
IAmByB
Post by IAmByB » Tue Jan 31, 2017 8:57 pm
I have one more question about Vintasoft barcodes writer :
If I create a barcode 128 with :
SetMinWidth(0.375,MeasurementUnit.Millimeters);
the value of MinWidth property is 2 px
SetMinWidth(0.7,MeasurementUnit.Millimeters);
the value of MinWidth property is the same (2 px)
I thought that the MinWidth value was going to change when I change the value used in SetMinWidth().
Can you explain me why is the MinWidth value the same in both cases, and how can I make vary ?
Thank you very much.
