Barcode Writer SDK Base64 String Exception
sss123mike
Post by sss123mike » Fri May 05, 2017 6:42 pm
Hello.
I have just purchased and downloaded the Barcode Writer SDK.
I have installed, referenced and registered DLL.
I am trying to create a barcode using the exact code from the online documentation:
' create the barcode writer
Dim barcodeWriter As New BarcodeWriter()
' set barcode writer settings
barcodeWriter.Settings.Barcode = BarcodeType.Code128
barcodeWriter.Settings.Value = "012345abcde"
' get a barcode image
Dim image As Image = barcodeWriter.GetBarcodeAsBitmap()
' save the barcode image to a file
image.Save("imageWihBarcode.png")
When I run the above code I get the exception:
"The input is not a valid Base-64 string as it contains a non-base 64 character, more than two padding characters, or an illegal character among the padding characters."
Can anyone help with this?
Thanks in advance.
Mike
Re: Barcode Writer SDK Base64 String Exception
Post by Alex » Fri May 05, 2017 10:08 pm
Hello Mike,
You have the licensing problem because you are using wrong reg.code - I think your email client broke your reg.code. Please contact out support at support@vintasoft.com and they will send you reg.data in text file.
sss123mike
Post by sss123mike » Sat May 06, 2017 3:06 pm
Hi Alex.
Thank you for your quick response.
You were correct, the reg code was wrong. I opened the email in another client and copied it from there.
All sorted now.
Thanks again.
Mike
