Rotate the Image Collection
rowdybull
Post by rowdybull »
This is the code from the example now. I would like to be able to pass in the entire collection and have a rotate all 90, 180, 270 option as well. Has anyone achieved this?
case "Rotate90Button":
case "Rotate180Button":
case "Rotate270Button":
    var angle = 90;
    if (id === "Rotate180Button")
        angle = 180;
    else if (id === "Rotate270Button")
        angle = 270;
    var ajaxParams = {
        type: 'POST',
        data: {
            twainSessionId: twainSessionId,
            imageId: imageId,
            angle: angle,
            thumbnailWidth: _thumbnailWidth,
            thumbnailHeight: _thumbnailHeight
    request = new Vintasoft.Shared.WebRequestJS("RotateImage",
        __modifiedImage_success,
        __processing_fail,
        ajaxParams);
    break;
Re: Rotate the Image Collection
Do you want to rotate image for preview or saving?
You can rotate all images in web image viewer using WebImageViewerJS.set_ImageRotationAngle function.
You can rotate separate image(s) in web image viewer using WebImageViewerJS.setCustomImageRotationAngle function.
If you want to rotate images and save rotated images to a file, you need to rotate images using WebRotateCommandJS class and save images to a file.
