File in use after appending tif page
philip.y
Post by philip.y » Tue May 31, 2011 11:21 pm
I'm getting a file in use when tring to delete the file I am appending. I've tried disposing the tif object but this crashes the app.
  Private Function AppendPage(ByVal sourceFile As String, ByVal newPage As String) As Boolean
        Dim tif As New Vintasoft.Imaging.Codecs.Tiff.TiffFile(sourceFile)
        Try
            tif.Pages.Add(New VintasoftImage(newPage))
            tif.SaveChanges()
        Catch ex As Exception
            Throw
        End Try
        Return True
    End Function
' Subsequent delete generates the error:
IO.File.Delete(newPage)
[/color]
Any ideas?
Re: File in use after appending tif page
Post by Alex » Wed Jun 01, 2011 10:43 am
Hello Philip,
You need to save a reference to the VintasoftImage object and dispose this object before removing the file.
Here is correct code:
    Using tif As New Vintasoft.Imaging.Codecs.Tiff.TiffFile(sourceFile)
        Try
            Using image As VintasoftImage = New VintasoftImage(newPage)
                tif.Pages.Add(image)
                tif.SaveChanges()
            End Using
            Throw
         End Try
    End Using
    Return True
End Function
philip.y
Post by philip.y » Wed Jun 01, 2011 5:44 pm
Alex,
Great - works a treat thanks!
Phil
