Exception in Rotate Image
ruserNET
Post by ruserNET » Tue May 19, 2009 11:35 pm
Alex,
I am trying to rotate an image by using the example in ImageViewer Demo Application. Here is a link to the demo application with my changes. This one throws the exception.
http://www.box.net/shared/sa7g3dpv29
My image is loaded in ImageViewer control and I call Rotate(90) on the FocusedImage, just as in ImageViewer Demo.
The only difference between my code and ImageViewer Demo is in
Line 77 of ImageViewerDemo.cs
In Demo it is
imageViewer1.Images.Add(openFileDialog1.FileName);
In demo the Image is loaded by File Path and
I need to load the image using Stream. So the line 77 looks like this
using (FileStream fs = File.Open(openFileDialog1.FileName, FileMode.Open))
imageViewer1.Images.Add(fs);
fs.Close();
It loads the image fine but when I right click and rotate it, throws this exception.
The exception is 'Rotate: Image is too big and cannot be processed."
The reason I need to load the image as a stream is because I do not want to lock the file. And the same image could be used/or be in use by other application.
Could you please let me know if there is a workaround for this or a fix can be provided for this.
Satrsi
Re: Exception in Rotate Image
Post by Alex » Wed May 20, 2009 10:43 am
Hi Satrsi,
The exception "Image is too big and cannot be processed" in the VintasoftImage.Rotate(90) method means that Bitmap object had thrown an ExternalException exception in the Bitmap.Rotate(FlipRotateFlipType.Rotate90FlipNone) method.
What is the size of your image? We will create a custom rotation algorithm for big images in next version of library.
ruserNET
Post by ruserNET » Wed May 20, 2009 5:12 pm
Alex,
ImageViewer is very good in handling Tiff files. I have not had any problems in any of the image file. I think the main problem is with loading the image as a stream.
The images I am trying are small 25 KB and 85KB. Here are the links to them
Image 1
http://www.box.net/shared/55dqcagke5
Image 2
http://www.box.net/shared/zqsc6aa05b
and the link to demo where I load the image as stream(this is same as the last post). This one says 'Image too big'
Project that throws Image too big to rotate on the above Images
I tried couple of different ways to load image
- by opening FileStream and copying it to MemoryStream and then calling ImageViewer.Images.Add(stream)
- by not closing the FileStream also.
But both of them eventually fail. It loads the image fine, and when rotating it says 'unsupported format'. Here is the link to the project which tries to
rotate the image after opening image in a stream.
Project that throws unsupported image on the above Images, after opening them successfully
http://www.box.net/shared/la1kk48ivh
Could you please try these samples and let me know if I am doing something wrong in loading the Image as a stream or (byte[])?
Satrsi
Post by Alex » Thu May 28, 2009 9:42 am
Hi Satrsi,
About your project that throws Image too big to rotate on the above Images:
You must keep the stream open for the lifetime of the VintasoftImage object.
Here is your code:
    fs.Close();
and here is correct code:
FileStream fs = File.Open(openFileDialog1.FileName, FileMode.Open);
also you can use this code:
byte[] buf = File.ReadAllBytes(openFileDialog1.FileName);
imageViewer1.Images.Add(new MemoryStream(buf));
Project that throws unsupported image on the above Images, after opening them successfully:
I cannot reproduce the problem - all is working fine. Please send me step-by-step instruction how to reproduce the problem.
