Page 3 of 3
Posted: Wed Feb 01, 2012 2:34 pm
Please send your JPEG file to support@vintasoft.com - we need to analyze it.
Posted: Thu Feb 02, 2012 8:16 am
Here is a code of console application which shows sorted metadata of JPEG file:
Imports System.IO
Module Module1
    Sub Main()
        Using jpegStream As FileStream = New FileStream("..\..\053.jpg", FileMode.Open, FileAccess.Read)
            Using jpeg As JpegFile = New JpegFile(jpegStream)
                If exif Is Nothing Then
                    Console.WriteLine("JPEG file does not have EXIF data.")
                Else
                    WriteTagsData("EXIF", exif.ExifTags, GetType(ExifTagId))
                    WriteTagsData("GPS", exif.GpsTags, GetType(GpsTagId))
            End Using
        End Using
        Console.WriteLine("Press any key to continue...")
        Console.ReadKey()
    End Sub
    Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection, ByRef tagIdEnumType As Type)
        If tags.Count = 0 Then
            Console.WriteLine(String.Format("No {0} data.", tagsName))
        Else
            Console.WriteLine(String.Format("{0} data [{1}]:", tagsName, tags.Count))
            Dim tag As TiffTag
            Dim tagData As Object
            Dim tagDataAsArray As Array
            Dim tagDataAsString As String
            ' for each tag in tag collection
            For i = 0 To tags.Count - 1
                ' get tag
                tag = tags(i)
                ' get tag data
                tagData = tag.Data
                ' if tag data is array
                If IsArray(tagData) Then
                    tagDataAsString = "[ "
                    tagDataAsArray = CType(tagData, Array)
                    For j = 0 To tagDataAsArray.Length - 1
                        tagDataAsString = tagDataAsString + tagDataAsArray(j).ToString + "; "
                    Next
                    tagDataAsString = tagDataAsString + "]"
                    ' if tag data is NOT array
                Else
                    tagDataAsString = tagData.ToString()
                ' add information about tag to textbox
                Console.WriteLine(String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.GetName(tagIdEnumType), tag.Id, tag.Type, tagDataAsString))
            Next
        Console.WriteLine()
    End Sub
End Module
Posted: Fri Feb 03, 2012 7:57 am
by js95007
Hey Alex, thanks for that latest code, however for my purposes it needs to be in a Windows Form Application.
The previous code worked well in that sense, so all I need is a way to extract the longitude and latitude themselves and display in a textbox, much like what communi needed on Page 1 of this thread.
The latitude for example is displayed like this -
Name=GPSLatitude, Id=2, Type=Rational, Data=[ 35 / 1; 43 / 1; 475 / 100;
where as the real latitude for the picture is 35 43 4.75
If there was a way to have a textbox for longitude reading that and one for latitude doing the same, that would be great.
Thanks again
Posted: Fri Feb 03, 2012 10:28 am
–°ode from previous post shows you how to get information about GPS metadata from JPEG file, further coding is your work as a programmer. :-)
Please contact our sales team at sales@vintasoft.com if you need custom programming.
Posted: Fri Feb 03, 2012 10:52 am
by js95007
Fair enough, I think I've cracked it anyway :D
Thanks again for all your help
