Printing Some Pages
TheHoff
Printing Some Pages
Post by TheHoff » Wed Nov 06, 2013 1:08 pm
Hi
When I call the ImagePrintDocumet.Print() method it always prints all pages even when I set the "from" and "to" in the print dialogue and set PrinterSettings.PrintRange = PrintRange.SomePages
I've also tried setting manually setting "from" and "to" in printer settings.
ipd.PrinterSettings.FromPage = 2;
ipd.PrinterSettings.ToPage = 2;
My code is based on the sample code, which I must say seems bizarre. You call the .Print() method which seems to then fire an event once for each page in the image. The event uses a page count to track which page to print. :?: :?:
        void ipd_PrintImage(object sender, PrintImageEventArgs e)
            if (currentPage < ic.Count)
                e.Image = ic[currentPage];
                currentPage++;
                if (currentPage >= ic.Count)
                    e.HasMoreImages = false;
                    currentPage = 0;
                    e.HasMoreImages = true;
I'm sure I could find a way round this by splitting the image up into single page images and printing the ones I want BUT the fact that you can set this property (PrinterSettings.PrintRange = PrintRange.SomePages) would suggest that this approach is not necessary.
Any help gratefully accepted :)
Mark
Re: Printing Some Pages
Post by Alex » Wed Nov 06, 2013 8:14 pm
Hello Mark,
Please read how to print images in WinForms in the documentation:
http://www.vintasoft.com/docs/vsimaging ... Forms.html
