Click event on WpfImageViewer
waxwings
Post by waxwings » Fri Oct 31, 2014 7:28 pm
i would like to catch the click event on a WpfImageViewer with PDF Coordinates (to tell where the user has clicked on a pdf page). Is it possible? I would also like to show some rectangles on the pdf pages programmatically. How can i do that?
Best Regards
Yimei
Re: Click event on WpfImageViewer
Post by Alex » Sat Nov 01, 2014 9:34 am
Hi Yimei,
Yes, this is possible. For doing the task you need:
  • Subscribe to the WpfImageViewer.MouseDown event
  • In handler of WpfImageViewer.MouseDown event
This is also possible. Please read how to do this here: http://www.vintasoft.com/docs/vsimaging ... fPage.html
waxwings
Post by waxwings » Mon Nov 03, 2014 1:57 pm
thanks for the reply. I tried the MouseDown event. It works however only on the right mouse click. I would like to work with the left mouse click event. Is it possible?
Best Regards
Yimei
waxwings
Post by waxwings » Mon Nov 03, 2014 5:02 pm
hi Alex,
could you please also tell me what ist the measurement of the Point if i get it from the PointToImage method?
Best Regards
Yimei Liao
Post by Alex » Mon Nov 03, 2014 5:55 pm
Hi Yimei,
There is no difference when you work with left or right mouse button. Could you share a snippet of your code?
The PointToImage method (http://www.vintasoft.com/docs/vsimaging ... Image.html) returns point coordinate in pixels.
waxwings
Post by waxwings » Mon Nov 03, 2014 6:01 pm
here is my code
imageViewer.MouseDown += new MouseButtonEventHandler(Pdf_MouseDown);
private void Pdf_MouseDown(object sender, MouseEventArgs e)
Pdf_MouseDown is only triggered by the right mouse click.
Best Regards
Yimei Liao
Post by Alex » Mon Nov 03, 2014 6:18 pm
Here is my code:
this.imageViewer1.MouseClick += new System.Windows.Forms.MouseEventHandler(this.imageViewer1_MouseClick);
this.imageViewer1.MouseDown += new System.Windows.Forms.MouseEventHandler(this.imageViewer1_MouseDown);
private void imageViewer1_MouseDown(object sender, MouseEventArgs e)
    MessageBox.Show("MouseDown " + e.Button.ToString());
private void imageViewer1_MouseClick(object sender, MouseEventArgs e)
    MessageBox.Show("MouseClick " + e.Button.ToString());
and it works correctly for left and right mouse buttons.
Please send working demo project which demonstrates the problem to support@vintasoft.com, we need reproduce your problem.
waxwings
Post by waxwings » Tue Nov 04, 2014 6:08 pm
the MouseClick Event is not available. I would send you the example codes sortly.
Best regards
Yimei
waxwings
Post by waxwings » Tue Nov 04, 2014 6:21 pm
i have yet another problem. I have some pdf documents, each containing only one page. I open the pdfs one after another, while showing a Rectangular on each of them. Problem is that sometimes the Rectangular shows and sometimes not. It looks like a race condition to me. My codes are like
private void NextPdf_Click(){
openDocument(nextIndex);
showRectangular();
        private void showRectangulars()
            using (PdfGraphics graphics = PdfGraphics.FromPage(FocusedPage))
                System.Drawing.PointF p = new System.Drawing.PointF((float)x, (float)y);
                FocusedPage.PointToUnit(ref p);
                System.Drawing.Color brushColor = System.Drawing.Color.FromArgb(0, 0, 0);
                PdfBrush brush = new PdfBrush(brushColor, GraphicsStateBlendMode.Multiply);
                PdfPen pen = new PdfPen(brushColor);
                graphics.FillAndDrawRectangle(pen, brush, 100, 100, 200, 200);
            imageViewer.Image.Reload(true);
        private void OpenDocument(int index)
                CloseDocument();
                PdfDocumentController.AuthenticateRequest += new EventHandler<PdfDocumentOpenedEventArgs>(PdfDocumentController_AuthenticateRequest);
                String filename = VM.getPdfName(index);
                    // try open in read-write mode
                    _documentStream = new FileStream(filename, FileMode.Open, FileAccess.ReadWrite);
                catch (IOException)
                        // try open in read mode
                        _documentStream = new FileStream(filename, FileMode.Open, FileAccess.Read);
                    catch (IOException e)
                        Debug.Write(e);
                        return;
                catch (Exception e)
                    Debug.Write(e);
                    return;
                    _document = PdfDocumentController.OpenDocument(_documentStream);
                    if (_document.IsEncrypted && _document.AuthorizationResult == AuthorizationResult.IncorrectPassword)
                        CloseDocument();
                        return;
                catch (Exception e)
                    Debug.Write(e);
                    CloseDocument();
                    return;
                _document.RenderingSettings.UseEmbeddedThumbnails = true;
                    imageViewer.Images.Add(_documentStream);
                catch (Exception e)
                    Debug.Write(e);
                    CloseDocument();
                    return;
        /// get the password from the AppConfiguration
        void PdfDocumentController_AuthenticateRequest(object sender, PdfDocumentOpenedEventArgs e)
            PdfDocument document = e.Document;
            while (true)
                AuthorizationResult authorization = document.Authenticate(AppConfiguration.PDF_DECRYPTION_KEY);
                if (authorization == AuthorizationResult.IncorrectPassword)
                    Console.WriteLine("The password is incorrect.");
                    Console.WriteLine(authorization.ToString());
                    return;
Best regards
Yimei
Post by Alex » Wed Nov 05, 2014 11:29 am
Hi Yimei,
I think your code has logical mistake. Please send working demo project which demonstrates the problem to support@vintasoft.com, we need reproduce your problem.
