Detecting cameras on citrix
BillG
Post by BillG » Tue Apr 21, 2015 4:43 pm
We have the vintasoft portion of our application working perfectly on desktop machines. The issue we are having is when the software is run on a citrix server, it sees the camera on the server, but it is unable to start the camera. Is there anything we have to do differently to start a camera on a citrix server than on a desktop. We do have a valid license for the server. at the top of the viewer it properly displays the name of the camera on the citrix server it just does not start the servers camera.
Re: Detecting cameras on citrix
Post by Alex » Wed Apr 22, 2015 9:39 am
Hi Bill,
Do you have any error or exception when you trying to start the camera? Please send us more info about your problem.
BillG
Post by BillG » Sun May 03, 2015 4:38 pm
when i click the start button i get the following exception. I should add the code works on a standalone machine. the only problem is when it is run on a citrix server. I can see the name of the camera above the viewer control so it seems to be able to detect the camera. And Yes we are checking for the appropriate licenses in our code.
cannot start camera or fetch image
System.ArgumentException: Value does not fall within the specified range.
here is the code where the problem is
        private void SlaveWebcamViewer_Click(object sender, EventArgs e)     // this is the code attached to the start button
            WebcamViewer viewer = (WebcamViewer)sender;
            if (viewer.CaptureDevice != null)
                MasterWebcamViewer.CaptureDevice = viewer.CaptureDevice;
                    MasterWebcamViewer.Start();              //this is the line prodcuing the exception
                catch (Exception ex)
                    ShowErrorMessage(ex);
Here is my constructor to initialize the viewer.
        public WebcamViewerForm()
            InitializeComponent();
            _slaveViewers = new WebcamViewer[]
                ImageViewer1,
                ImageViewer2
            _viewers = new WebcamViewer[]
                MasterWebcamViewer,
                ImageViewer1,
                ImageViewer2
            MasterWebcamViewer.CaptureTimeout = 5; // ms
            MasterWebcamViewer.SizeMode = ImageSizeMode.BestFit;
            foreach (WebcamViewer viewer in _slaveViewers)
                viewer.SizeMode = ImageSizeMode.BestFit;
                viewer.CaptureTimeout = 1000/25; // ms
            _captureDevicesMonitor = new ImageCaptureDevicesMonitor();
            _captureDevicesMonitor.Timeout = 500;
            _captureDevicesMonitor.CaptureDevicesChanged += new EventHandler<ImageCaptureDevicesChangedEventArgs>(CaptureDevicesMonitor_CaptureDevicesChanged);
            _captureDevicesMonitor.Start();
     private void WebcamViewerForm_Shown(object sender, EventArgs e)
            ReadOnlyCollection<ImageCaptureDevice> devices = ImageCaptureDeviceConfiguration.GetCaptureDevices();
            int viewerIndex = 0;
            foreach (ImageCaptureDevice device in devices)
                switch (viewerIndex)
                    case 0:
                        MasterWebcamViewer.CaptureDevice = device;
                        _slaveViewers[0].CaptureDevice = device;
                        break;
                    case 1:
                        _slaveViewers[1].CaptureDevice = device;
                        break;
                viewerIndex++;
            if (MasterWebcamViewer.CaptureDevice != null)
                Camera1Name.Text = MasterWebcamViewer.CaptureDevice.FriendlyName;
                Camera1Name.Text = "No Camera Found";
            if (_slaveViewers[1].CaptureDevice != null)
                Camera2Name.Text = _slaveViewers[1].CaptureDevice.FriendlyName;
                Camera2Name.Text = "No Camera Found";
            StartAll();
The form is similar to your one example. there are two slave viewers at the top of the form and a master viewer in the bottom half.
Post by Alex » Tue May 05, 2015 11:48 am
Hello Bill,
Please provide information about stack trace of exception.
BillG
Post by BillG » Wed May 06, 2015 12:14 am
Cannot start camera or fetch image
System.ArgumentException: Value does not fall within the expected range.
at System.Runtime.InteropServices.Marshall.ThrowExceptionForHRInteral(Int32 errorCode, intPtr errorinfo)
at System.Runtime.InteropServices.Marshall.ThrowExceptionForHR(Int32 errorCode)
at 5.t.I()
at 5.t.Start()
at Vintasoft.Imaging.Media.ImageCaptureDevice.1(ImageCaptureSource)
at Vintasoft.Imaging.Media.ImageCaptureSource.Start()
at UnionAdministrator.Helpers.WebcamViewer.Start()
Post by Alex » Sun May 10, 2015 12:26 pm
Hello Bill,
Thank you for information.
Your exception means that one or more DirectShow filters failed to run.
Please do the following tests:
  • Run our Imaging Demo on your Citrix server and try to capture images from webcam
  • Try to use webcam using different softwares
  • Try to run your application with administraive privileges
and let me know results.
