Save annotations separately in Multipage TIFF?
Posted: Thu Apr 30, 2009 2:43 pm
We like the ability of your components to save annotations as separate XMP files and have a business case where this would be very useful. I've got this working for single-image TIFF files using the following code:
The problem I have is that I can't get this working with multipage TIFF's. As far as I'm aware, I can only save multipage TIFFs by calling Save() on an ImageCollection. But when you do this, it ALWAYS saves the annotations (apparently within the TIFF file as I can't see a separate XMP file - is that correct?). What I want to do is:
1. Save all images in ThumbnailViewer as a Multipage TIFF without annotations
2. Save all images in ThumbnailViewer as a Multipage TIFF with separate XMP file
3. Save selected images in ThumbnailViewer as a Multipage TIFF without annotations
4. Save selected images in ThumbnailViewer as a Multipage TIFF with separate XMP file
Is this possible? If so, can you provide me with some example code for each of these requirements?
Ian
//save files
for (int i = 0; i < imageViewer1.Images.Count; i++)
//save each image as single file
VintasoftImage img = imageViewer1.Images[i] as VintasoftImage;
string newImageFileName = string.Format("{0}_{1}{2}", fileName, i.ToString().PadLeft(4, '0'), fileExt);
if (encoder != null)
img.Save(newImageFileName, encoder);
img.Save(newImageFileName);
if (saveAnnotationsToolStripMenuItem.Checked)
//save annotations
SaveAnnotations(i, ChangeFileExtension(newImageFileName, EXT_XMP));
private void SaveAnnotations(int imageIndex, string filePath)
if (imageViewer1.Annotations[imageIndex].Count > 0)
XmlDocument doc = imageViewer1.Annotations[imageIndex].Save();
doc.Save(filePath);
Ian
