Loading EmbeddedImageAnnotations from XML
m.zuidhoek
Post by m.zuidhoek » Thu Apr 14, 2011 4:57 pm
Hello there,
Currently I'm trying to save annotations to a XML file so they can be edited at a later time. However, every time i try to load the XML file, any EmbeddedImageAnnotations stored in the file are not loaded. I checked the XML files to make sure the annotations were saved at all, but they are present in the file. Checking the AnnotationCollection after the loading shows that the EmbeddedImageAnnotations are in fact not loaded, leaving me clueless as to where they have gone to.
Does anyone have a idea why only this type of annotations won't show up after loading the file?
I'll include a piece of XML Code that contains one of the EmbeddedImageAnnotations
<SymbolAnnotation assembly="ctlAnnotation" namespace="ctlAnnotation">
<Guid type="System.Guid">
<![CDATA[ ab0441f9-cf6c-4d31-963e-0ce57d2ca2af]]>
</Guid>
<CreationTime type="System.String">
<![CDATA[ 2011-04-14T15:10:29]]>
</CreationTime>
<ModifiedTime type="System.String">
</ModifiedTime>
<Location type="System.String">
<![CDATA[ 112,69.5]]>
</Location>
<Rotation type="System.Single">0</Rotation>
<Size type="System.String">
<![CDATA[ 24,24]]>
</Size>
<Visible type="System.Boolean">True</Visible>
<HorizontalMirrored type="System.Boolean">False</HorizontalMirrored>
<VerticalMirrored type="System.Boolean">False</VerticalMirrored>
<Border type="System.Boolean">False</Border>
<ZOrder type="System.Int32">0</ZOrder>
<BackColor type="System.Int32">-1</BackColor>
<Outline type="Vintasoft.Annotation.AnnotationPen">
<Width type="System.Single">1</Width>
<Color type="System.Drawing.Color">-16777216</Color>
<DashOffset type="System.Single">0</DashOffset>
<MiterLimit type="System.Single">10</MiterLimit>
<Brush type="System.Drawing.Brush">Solid FF000000</Brush>
</Outline>
<Symmetry type="System.Boolean">False</Symmetry>
<Brush type="System.String">Solid FFFFFFFF</Brush>
<ImageData type="System.String">
<![CDATA[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]]>
</ImageData>
</SymbolAnnotation>
M. Zuidhoek
Re: Loading EmbeddedImageAnnotations from XML
Post by Alex » Thu Apr 14, 2011 5:07 pm
You have created custom annotation as I have understood. We need to reproduce your problem - please send us code of your custom annotation class and XMP file with annotation.
m.zuidhoek
Post by m.zuidhoek » Mon Apr 18, 2011 9:56 am
Here's the code of the custom annotation class:
Imports Vintasoft.Annotation
Public Class SymbolAnnotation
    Inherits EmbeddedImageAnnotation
    Public File As Bitmap
    Private ColorChanger As ColorManager
    Public Sub New(ByVal Image As Bitmap)
        ColorChanger = ColorManager.GetInstance()
        ColorChanger.File = Image
        Me.Image = Image
        File = Image
    End Sub
    Public Overrides Function Clone() As Object
        Dim Result As New SymbolAnnotation(File)
        CopyTo(Result)
        Return Result
    End Function
    'Executes actions that must be done before the user starts building the annotation (like setting color)
    Protected Overrides Sub OnStartBuilding(ByVal point As System.Drawing.PointF)
        point = New PointF(point.X + 24, point.Y)
        MyBase.OnStartBuilding(point)
        Me.Border = False
        Me.Image = ColorChanger.ChangeColor()
    End Sub
    'The actual building
    Protected Overrides Sub OnBuilding(ByVal mouse As System.Windows.Forms.MouseEventArgs, ByVal action As Vintasoft.Annotation.MouseActions)
        MyBase.OnBuilding(mouse, action)
    End Sub
    'Actions that will be executed when building is complete (like checking if the annotation isn't so small it will become invisible when unselected)
    Protected Overrides Sub OnFinishBuilding(ByVal point As System.Drawing.PointF)
        MyBase.OnFinishBuilding(point)
        CheckAndSetHeight()
        CheckAndSetWidth()
    End Sub
    Private Sub CheckAndSetHeight()
        If (Me.Size.Height < 24) Then
            Me.Size = New SizeF(Me.Size.Width, 24)
    End Sub
    Private Sub CheckAndSetWidth()
        If (Me.Size.Width < 24) Then
            Me.Size = New SizeF(24, Me.Size.Height)
    End Sub
End Class
Most alterations on the basic EmbeddedImageAnnotation have to do with setting properties such as border and size. I don't think it's anything out of the ordinary.
Also, a full XML file containing 2 EmbeddedImageAnnotations (it should be a image of an arrow on both occasions):
<?xpacket begin='' id='W5M0MpCehiHzreSzNTczkc9d'?>
<x:xmpmeta xmlns:x="adobe:ns:meta/">
  <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
    <rdf:Description rdf:about="" xmlns:xmp="http://ns.adobe.com/xap/1.0/">
      <xmp:CreatorTool>Vintasoft Annotation Library 3.1</xmp:CreatorTool>
      <xmp:CreateDate><![CDATA[2011-04-14T15:10:31]]></xmp:CreateDate>
    </rdf:Description>
    <rdf:Description rdf:about="Vintasoft Annotations" xmlns:xmp="http://ns.adobe.com/xap/4.0/">
      <Annotations>
          <Guid type="System.Guid"><![CDATA[ab0441f9-cf6c-4d31-963e-0ce57d2ca2af]]></Guid>
          <CreationTime type="System.String"><![CDATA[2011-04-14T15:10:29]]></CreationTime>
          <ModifiedTime type="System.String"><![CDATA[2011-04-14T15:10:29]]></ModifiedTime>
          <Location type="System.String"><![CDATA[112,69.5]]></Location>
          <Size type="System.String"><![CDATA[24,24]]></Size>
          </Outline>
          <ImageData type="System.String"><![CDATA[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]]></ImageData>
        </SymbolAnnotation>
          <Guid type="System.Guid"><![CDATA[7132164a-bf9e-44de-b2c2-d8707c933782]]></Guid>
          <ModifiedTime type="System.String"><![CDATA[2011-04-14T15:10:30]]></ModifiedTime>
          <Location type="System.String"><![CDATA[93,29]]></Location>
          <Size type="System.String"><![CDATA[28,24]]></Size>
          </Outline>
        </SymbolAnnotation>
      </Annotations>
    </rdf:Description>
  </rdf:RDF>
</x:xmpmeta>
<?xpacket end='r'?>
Yuri
Post by Yuri » Tue Apr 26, 2011 4:17 pm
To be successfully deserialized the annotation code must contain constructor without params like below:
    Public Sub New()
    End Sub
So we've a bit modificated your code and now you'll be able to deserialize the annotation.
    Public Sub New()
    End Sub
        Me.Image = Image
        File = Image
    End Sub
        CopyTo(Result)
        Return Result
    End Function
        Me.Border = False
    End Sub
    End Sub
        CheckAndSetHeight()
        CheckAndSetWidth()
    End Sub
    End Sub
    End Sub
End Class
m.zuidhoek
Post by m.zuidhoek » Wed Apr 27, 2011 10:41 am
Hello Yuri,
That code worked like a charm! Now i'm able to reload the image annotations.
Thank you very much.
M.Zuidhoek
