add bookmark in annotion viewer
GHWels
Post by GHWels » Mon Nov 21, 2016 2:06 pm
Hello
Is it possible to add bookmarks to image?
thank you
Best regards, GHWels
Re: add bookmark in annotion viewer
Post by Alex » Mon Nov 21, 2016 3:11 pm
You can add annotation to an image. A list of supported annotations can be found here: http://www.vintasoft.com/docs/vsimaging ... _Data.html
GHWels
Post by GHWels » Mon Nov 21, 2016 6:40 pm
Hello Alex!
Sorry my question was not exact.
I added annotions to an image or PDF. (that works)
I want to add PDF-bookmarks in the annotion- or image-viewer and save it as PDF.
Best regards GHWels
Post by Alex » Tue Nov 22, 2016 7:23 pm
Hello Gunther,
Please do the following steps:
  • Run our PDF Editor Demo v8.4
  • Open multipage PDF document
  • Select the "Annotations / Form Fields" tab
  • Select the Edit mode in the "Interaction Mode" group
  • Select "Link" annotation on the "Annotations" tab and add annotation to a PDF page, the "Create Action" dialog will appear
  • Select "Goto Action" in the "Create Action" dialog, click "Ok" button - the "Goto Action Editor" dialog will appear
  • Select the necessary page index and position in the "Goto Action Editor" dialog, click "Ok" button - Link annotation will appear on PDF page
  • Select the Markup mode in the "Interaction Mode" group
  • Click on Link annotation on PDF page and you will be navigated to another PDF page
  • Save changes in PDF document if necessary
Is this functionality suitable for your needs?
