Winforms - Show distance value of the ruler annotation to a text field.
markdhem
Post by markdhem » Thu Jul 05, 2018 9:47 am
Hi there,
How can I fetch the distance of the ruler annotation to a text field in C# just like the image below.
Thank you in advance. :)
Best Regards,
Mark
Re: Winforms - Show distance value of the ruler annotation to a text field.
Post by Alex » Fri Jul 06, 2018 9:26 am
Hi Mark,
URL to your image is broken, please add new image.
You can get the length of ruler using the RulerAnnotationData.Length property:
https://www.vintasoft.com/docs/vsimagin ... ength.html
You can get the unit of measure of ruler using the RulerAnnotationData.UnitOfMeasure property:
https://www.vintasoft.com/docs/vsimagin ... asure.html
markdhem
Post by markdhem » Fri Jul 06, 2018 9:35 am
Thanks for your reply,
Here is my screenshot, https://drive.google.com/open?id=18Qsda ... qt5M1SU6Li.
I actually got it at
annotationViewer1_AnnotationTransformingFinished
now but it will only appears the pixels value. What I want is the millimeters.
Here is my code.
foreach (AnnotationView view in annotationViewer1.SelectedAnnotations)
    // end the initialization of annotation view
    EndInit(view.Data);
    var size = view.Data.Size.Width;
    var mmSize = size ; //What is the formula here?
    textBox2.Text = mmSize.ToString();
Regards,
Mark
Post by Alex » Fri Jul 06, 2018 10:44 am
You can change the unit of measure using the RulerAnnotationData.UnitOfMeasure property:
