Scanning Area / PageSize
Posted: Sun Oct 12, 2014 5:42 pm
by meimad
Hi
I'm Using ms access 2007 and I want to set the page width and height (same as scanning area using the ui)
my scanner is fi-6130. The width is 170mm and the height is 70mm.
I'm using the following code (from the faq)
VintaSoftTwain1.StartDevice
If VintaSoftTwain1.SelectSource() = 1 Then         ' select the device
    VintaSoftTwain1.ShowUI = False                 ' disable UI
    VintaSoftTwain1.DisableAfterAcquire = True
    VintaSoftTwain1.MaxImages = 1
    VintaSoftTwain1.AutoCleanBuffer = True
    VintaSoftTwain1.TiffMultiPage = True           ' multi page TIFF file
    VintaSoftTwain1.TiffCompression = 10           ' auto detect best
                                            ' compression algorithm
    If VintaSoftTwain1.OpenDataSource() = 1 Then
        VintaSoftTwain1.UnitOfMeasure = 1          ' centimeters
        VintaSoftTwain1.PixelType = 2              ' rgb
        VintaSoftTwain1.Resolution = 200           ' 200 dpi
        If VintaSoftTwain1.DUPLEX <> 0 Then
            VintaSoftTwain1.DuplexEnabled = True   ' enable duplex
        If VintaSoftTwain1.FeederPresent = 1 Then
            VintaSoftTwain1.XferCount = -1
            VintaSoftTwain1.FeederEnabled = True
            VintaSoftTwain1.AutoFeed = True
            If VintaSoftTwain1.FeederLoaded = 1 Then
                VintaSoftTwain1.Acquire
Re: Scanning Area / PageSize
Posted: Wed Oct 15, 2014 11:08 am
You can set page size using the VSTwain.PageSize property if you want to use predefined page size. List of supported page sizes can be get using the VSTwain.GetPageSizes method.
You can set page size using the VSTwain.SetImageLayout method if you want to set custom image size.
I think you have problems because you are using centimeters as unit of measure. Please use inches as unit of measure as shown in the code snippet below:
        VintaSoftTwain1.UnitOfMeasure = 0              ' inches
        VintaSoftTwain1.Resolution = 200                 ' 200 dpi (dots-per-inch)
        VintaSoftTwain1.SetImageLayout(1,1,5,5)    ' image layout is specified in inches
Posted: Sun Nov 09, 2014 12:53 pm
by meimad
I'll try it
