HP 5000 s2 scanner
Posted: Wed Dec 31, 2014 7:33 pm
by dendic@comcast.net
Running windows 7. Got new scanner ran setup disk and regsvr32 to register vsTwain.dll but when I scan from within Microsoft Access I get "No device found"
Re: HP 5000 s2 scanner
Posted: Thu Jan 01, 2015 2:00 pm
This message means that you do not have device driver in your system. Are you sure the device driver is installed in your system?
Posted: Fri Jan 02, 2015 8:56 pm
Yes I loaded the scanning software disk that came with the scanner and I have this scanner setup on other computers.
Posted: Mon Jan 05, 2015 9:18 pm
Alex any other ideas?
Posted: Wed Jan 07, 2015 10:09 am
Please try to use our demo, for example, TwainAdvancedDemo (TwainAdvanced.exe), and let me know results.
Posted: Wed Jan 07, 2015 9:11 pm
You don't seem to following my issue. I have been using the vstwain driver for 10 years I have it programmed into my Access program and works perfectly except for this one computer and this scanner(this scanner works on the other computers with the same setup) where I get "no device found". You suggested the driver is not installed but it was from the scanner diskette. My platform is Windows 7 and Microsoft Access 2010. Thank you
Posted: Thu Jan 08, 2015 4:54 pm
I have revised the error messages of ActiveX and have found that ActiveX does not have error message "No device found". Please share your code and send me an error code returned by ActiveX.
You can have problems because of the following reasons:
  • ActiveX has not found TWAIN device manager.
  • ActiveX has not found TWAIN device (driver).
