ask for next page with fladbled scanner
smarelis
Post by smarelis » Sun Sep 28, 2008 2:19 am
Hi, I have an canon lide 90 flatbled scanner, i would like to add an other page to my scan process, just like a manual auto feed.
is this possible? i cannot find any information in the manual.
if so can you give me an example.
Sjaak
Re: ask for next page with fladbled scanner
Post by Alex » Mon Sep 29, 2008 8:46 am
Hello Sjaak,
You should enable acquisition process in a loop if you want to acquire some pages from flatbed scanner.
Here is an example:
VSTwain1.appProductName = "MyTwainApplication"
If VSTwain1.StartDevice() Then
    VSTwain1.SelectSource
    VSTwain1.showUI = False
    Dim scanAnotherPath As Boolean
    scanAnotherPage = True
    While scanAnotherPage
        While VSTwain1.AcquireModal() = 1
            Set Image1.Picture = VSTwain1.GetCurrentImage()
            If VSTwain1.SaveImage(0, "c:\test.tiff") = 0 Then
                MsgBox(VSTwain1.errorString)
        Wend
        If MsgBox("Stop scan?") = MsgBoxResult.Ok Then
            scanAnotherPage = False
    Wend
Else
    MsgBox VSTwain1.errorString
smarelis
Post by smarelis » Mon Sep 29, 2008 1:03 pm
Dear Alex,
The code worked, only the second page has an bad quality.
Can you help me with te solution?
function Scan()
var randomnumber=Math.floor(Math.random()*11111111111111)
var imgPath = "c:\\Scan\\" + randomnumber + ".tiff"
VSTwain1.maxImages=10
VSTwain1.autoCleanBuffer=1
VSTwain1.disableAfterAcquire=1
VSTwain1.transferMode = 1
VSTwain1.ShowUI=0
VSTwain1.OpenDataSource()
VSTwain1.unitOfMeasure=0
VSTwain1.pixelType=0
VSTwain1.resolution=600
VSTwain1.autoBright = 1
VSTwain1.tiffMultiPage = 1
var scanAnotherPage = 1;
var iPage = 0;
while (scanAnotherPage)
while (VSTwain1.AcquireModal() == 1)
//var Image1 = VSTwain1.GetCurrentImage();
if (VSTwain1.SaveImage(iPage, imgPath) == 0)
alert(VSTwain1.errorString)
if (confirm("Wilt u nog een pagina scannen?") == 0)
scanAnotherPage = 0;
iPage++
catch (e)
SelectScanner();
alert("Probeer opnieuw de scan opdracht uit te voeren");
Post by Alex » Mon Sep 29, 2008 2:19 pm
You should initialize all necessary parameters for each scanned page. Here is corrected code:
function Scan()
        VSTwain1.ShowUI=0
        var iPage = 0;
            iPage++
    catch (e)
        SelectScanner();
