Version 7.2 of VintaSoftImaging.NET SDK has been released.
Posted: Tue Dec 24, 2013 3:44 pm
What's new in this version of VintaSoftDocCleanup.NET Plug-in:
What's new in this version of VintaSoftOCR.NET Plug-in:
- Created RAW files decoder with the following functionality:
- Supported RAW file formats: DNG, NEF, CR2, CRW, NRW.
- The ability to obtain thumbnail, image for preview or original image.
- The ability to obtain original image with or without interpolation. Supported are bilinear, gradient and adaptive interpolations.
- The ability to apply white balance color correction to the original image. Supported are automatic white balance, camera white balance and user-defined white balance.
- The ability to get image metadata.
- Added the decoding support for 2-bit BMP format in ICO files.
- Added the ability to disable the rendering settings management of image viewer.
- Multi Webcam Demo created, which demonstrates the ability to display video from several cameras on one form.
- Raw Image Viewer Demo created, which allows to preview all images from a RAW file (thumbnail, image for preview, original image). Original image can be obtained with or without interpolation and can be a subject for white balance color correction.
- Improved support of transparency in PDF documents:
- Added support for SoftMask parameter of graphical state.
- Added support of Transparency Group XObjects.
- Improved the drawing quality of rotated composite images in PDF.
- Fixed bugs in parsers of Type1 and CFF fonts.
- Added the ability to edit tiles of JPEG2000 image.
- Optimized the memory usage in JPEG2000 encoder.
- JPEG2000 encoder is accelerated up to 25%.
- Created new document cleanup commands:
- HalftoneRecognitionCommand - seeks for halftone regions on the image.
- HalftoneRemovalCommand - removes halftones from the image.
- RestoreTextFromHalftoneCommand - restores text in halftone regions on the image.
- The used Tesseract OCR Engine upgraded to version 3.02:
- Improved OCR quality.
- New supported languages: Afrikaans, Albanian, Azerbaijani, Belarusian, Bengali, Estonian, Basque, Frankish, Galician, Croatian, Icelandic, Malayalam, Macedonian, Maltese, Malay, Swahili, Tamil, Telugu.
- Some minor fixes.
