Version 6.0 of VintaSoftTwain ActiveX has been released.
Version 6.0.12.1 of VintaSoftTwain ActiveX has been released.
Post by Alex » Wed Nov 08, 2017 11:55 am
Version 6.0.12.1 of VintaSoft Twain ActiveX has been released.
What's new in this version:
  • Defined the formats for values of PdfEncoder_DocumentCreationDate and PdfEncoder_DocumentModificationDate properties. Information about supported formats can be found here: https://www.vintasoft.com/docs/vstwain/ ... nDate.html
Version 6.0.13.1 of VintaSoftTwain ActiveX has been released.
Post by Alex » Mon Mar 26, 2018 12:51 pm
Version 6.0.13.1 of VintaSoft Twain ActiveX has been released.
  • Fixed the bug in image processing commands Crop and ResizeCanvas.
Version 6.0.14.3 of VintaSoftTwain ActiveX has been released.
Post by Alex » Tue Mar 05, 2019 10:50 am
Version 6.0.14.3 of VintaSoft Twain ActiveX has been released.
  • Fixed the bug in AcquiredImages_Save method. The error could occur during image saving to a PDF document if PDF document date/time is specified.
Version 6.0.15.1 of VintaSoftTwain ActiveX has been released.
Post by Alex » Thu Mar 21, 2019 9:31 am
Version 6.0.15.1 of VintaSoft Twain ActiveX has been released.
  • Added the Device_Caps_WorkDirectly property, which allows to specify that the device must try to get / set the capability value even if capability is not present in device capability list.
Version 6.0.16.1 of VintaSoftTwain ActiveX has been released.
Post by Alex » Thu Apr 11, 2019 10:57 am
Version 6.0.16.1 of VintaSoft Twain ActiveX has been released.
  • Improved the algorithm of AcquiredImages_Deskew method.
