Version 8.5 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Apr 25, 2017 3:50 pm
We are proud to announce the release of new major version 8.5 of VintaSoft Imaging .NET SDK and the related Annotation, PDF,
What's new in v8.5 of VintaSoft Imaging .NET SDK:
  • Created the platform-independent web services. This allows to use Vintasoft web services on any .NET web platform, i.e. ASP.NET WebForms, ASP.NET MVC, ServiceStack, etc.
  • ASP.NET MVC 5 and jQuery v2-v3 supported.
  • The detailed information can be found here: https://www.vintasoft.com/vsimaging-dotnet-history.html.
What's new in v8.5 of VintaSoft PDF .NET Plug-in:
  • Added the ability to verify PDF documents for compliance with standards: PDF/A-1b, PDF/A-2b, PDF/A-3b.
  • Added the ability to convert PDF document into following formats: PDF/A-1b, PDF/A-2b, PDF/A-3b.
  • Added the ability to work with PDF document in multiple threads (rendering, getting thumbnails, text extraction, image extraction).
  • New types of PDF annotations supported: Ink, File Attachment.
  • Added the Cloudy style for the following PDF annotations: polygon, rectangle, free text.
  • Now PdfDocument class by default uses a controller of external fonts with fallback-font, i.e. any not found font will be replaced by default font.
  • New features added to PDF Reader Demo, PDF Editor Demo and PDF Structure Editor Demo.
  • The detailed information can be found here: https://www.vintasoft.com/vspdf-dotnet-history.html.
What's new in v8.5 of VintaSoft OCR .NET Plug-in:
  • The used Tesseract OCR engine has been updated to version 3.04.
  • Added the ability to use the Tesseract OCR engine in multithreaded environment.
  • Improved the quality of text recognition in color images.
  • Reduced the peak memory usage allocated during recognition of text in color images.
  • The detailed information can be found here: https://www.vintasoft.com/vsocr-dotnet-history.html.
What's new in v8.5 of VintaSoft Annotation .NET Plug-in:
What's new in v8.5 of VintaSoft DICOM .NET Plug-in:
What's new in v8.5 of VintaSoft Document Cleanup .NET Plug-in:
  • Created the processing command LineRecognitionCommand, which allows to perform the search of lines on the image.
  • Created the processing command LineFillingCommand, which allows to fill lines in the image.
  • The commands for removing and filling lines have been extended with ability to find the lines with breaks.
  • The detailed information can be found here: https://www.vintasoft.com/vsdoccleanup- ... story.html.
Version 8.5.1.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri May 05, 2017 12:26 pm
  • Fixed minor bug in JPEG encoder.
  • Fixed minor bug in GIF encoder.
  • Fixed minor bug in VintasoftImage.LoadingError and VintasoftImage.LoadingErrorString properties.
  • In PdfTextSelectionTool class fixed the bug in reverse text search algorithm.
  • Fixed minor bug in PDF/A verifier.
  • Improved the selection of PDF annotations, which have the Cloud border style.
  • Some minor fixes.
  • Now Line, Lines and Polygon annotations support the color blending in WinForms and WPF.
  • Now WANG annotations can be drawn highlighted. Valid only for lines, rectangles, and freehand.
  • Improved compatibility with Vintasoft annotations version 2.0 and earlier.
  • Some minor fixes.
  • Fixed minor bug in text recognition algorithm.
  • Now OCR Demo allows to change the setting for multithreaded text recognition.
Version 8.5.2.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri May 12, 2017 5:38 pm
  • Fixed the bug in algorithm that removes vector content from PDF document.
  • Fixed the bug in verifier and converter of PDF/A-1b documents.
  • Fixed the bug in visual tool WpfPdfAnnotationTool in algorithm that selects several annotations and interactive fields.
  • Added the blending support for WPF line-annotations with Cloud and Triangle line style.
Version 8.5.3.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri May 26, 2017 3:01 pm
  • Improved the TIFF decoder.
  • Minor improvements in web image viewers.
  • Improved the algorithm that renders PDF interactive field with multiline text.
  • Now PDF interactive field allows to limit the font size for text, which size is calculated automatically.
  • Added the ability to remove Image XObjects and Form XObjects from content of PDF page or PDF form.
  • Now PDF renderer takes into account the PdfImageResource.Interpolate flag.
  • Now PdfEditorDemo allows to use Ctrl+C/Ctrl+V shortcuts for copying/pasting text in text annotation and interactive fields.
Version 8.5.4.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Jun 21, 2017 12:19 pm
  • Fixed the bug in processing of 1-bpp or 4-bpp images, which appears in GetUniqueColorCommand class.
  • Improved the rendering of PDF documents, which contain thin lines.
  • Fixed the bug in rendering of images, for which TransferFunction was specified
  • Fixed the bug in rendering of text using ShadingPattern.
Version 8.5.5.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Jul 05, 2017 5:40 pm
  • Added the ability to decode palette TIFF images compressed with JPEG compression.
  • Improved the algorithm that determines text encoding for TrueType fonts.
  • Improved the algorithm that packs damaged PDF documents.
  • Fixed the bug in PDF/A converter. Now it is possible to open PDF document, add digital certificate to the PDF document, convert PDF document to PDF/A format and save PDF document to a new file.
Version 8.5.6.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu Jul 20, 2017 2:50 pm
  • Improved the XMP parser, which led to an improvement in the PDF/A verifier.
  • Improved the TrueType font parser.
  • Fixed the bug in parser of DICOM image metadata.
Version 8.5.7.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu Aug 03, 2017 3:39 pm
  • Added the ability to define the mechanism of state storage for Undo/Redo function. For example, earlier there was the ability to store Undo/Redo state history for image in memory only, but now it can be also stored on disk.
  • Fixed the bug in algorithm that draws image annotations in WinForms. The bug appeared since version 8.5.0.1.
  • Improved the algorithm that rotates image with annotations in web.
  • Fixed the bug in parser of TrueType fonts.
  • Fixed the bug in the DepthOfSaveGraphicsStateOperatorsGreaterThan28 trigger of PDF/A verifier.
  • Fixed the bug in the GraphicsStateParametersHasNonStrokingAlphaConstant and GraphicsStateParametersHasStrokingAlphaConstant triggers of PDF/A verifier.
Version 8.5.8.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Aug 16, 2017 3:51 pm
  • Now visual tool WpfZoomTool can work with touch screen and allows to use 2 fingers for zooming an image in WPF image viewer.
  • Now visual tool WpfPanTool can work with touch screen and allows to use finger for panning an image in WPF image viewer.
  • Improved the background color detection in Rotate command for 32-bpp images.
  • Added the ability to align multiline text in Stamp annotation.
  • Fixed the memory leak in Embedded annotation.
  • Fixed the bug in algorithm that renders PDF page, which have transparency stack.
Version 8.5.10.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri Sep 08, 2017 4:53 pm
  • Fixed the bug in parser of Type1 fonts.
What's new in this version of VintaSoft Forms Processing .NET Plug-in:
  • Added the ability to process form image before generating of image imprint.
  • Updated the FormsProcessingDemo project (WinForms):
    • Added the ability to select the image imprint generator. Available generators: image imprint generator based on lines; image imprint generator based on L-patterns.
    • Added the ability to change parameters of image imprint generator.
    • Added the ability to process the form image before generating of image imprint. Also now it is possible to preview processed image in image viewer.
    • Added the ability to view and compare imprints of template form image and filled form image.
    • Added the ability to view the result of form identification, i.e. view and compare key zones of template form image and filled form image.
