HP scanners.
HP scanners.
Here is a list of HP scanners tested with our products by us or our customers:
  • HP Color LaserJet CM1312
  • HP OfficeJet 6500
  • HP OfficeJet 6700 Premium
  • HP OfficeJet 7200
  • HP OfficeJet D125XI
  • HP OfficeJet T65XI
  • HP LaserJet Pro 500 color MFP M570dw
  • HP LaserJet Pro M1132
  • HP PSC 950
  • HP PSC 1310
  • HP PCS 1510
  • HP ScanJet 2200C
  • HP ScanJet 2400
  • HP ScanJet 3800
  • HP ScanJet 4600
  • HP ScanJet 5000
  • HP ScanJet 5470C
  • HP ScanJet 5550
  • HP ScanJet 5590
  • HP ScanJet 7400C
  • HP ScanJet 8250
  • HP ScanJet 8300
  • HP ScanJet Enterprise 7000 s2
  • HP ScanJet Enterprise 8500
  • HP ScanJet Enterprise 9000
  • HP ScanJet G2410
  • HP ScanJet G3010
  • HP ScanJet Flow N9120 fn2
HP scanners are very good scanners and we can recommend them for usage with our products.
If you have tested other HP scanner with our product and want to share your experience, please post it here. Thank you in advance.
BillG
Re: HP scanners.
Post by BillG »
I am testing the library with an HP Scanjet N6010 and so far it works just fine. I was getting a stackoverflow exception at first, but after setting
vsTwain1.ShowIndicators = false;
before I acquire the image, it worked fine.
Bill
Re: HP scanners.
There is a link related to the "Problems with TWAIN driver in N6010" topic on HP's forum.
rpellegrini
Re: HP scanners.
Post by rpellegrini »
I am testing using a HP Photosmart 7510. On one system, it works correctly on another system, the device will not open. So I guess that this scanner (all-in-one) only kind of works.
Re: HP scanners.
Please compare TWAIN driver of scanner on "good" and "bad" systems.
Re: HP scanners.
HP Scanjet Pro 2000 s1 is successfully tested by our client.
Re: HP scanners.
HP LaserJet Pro MFP M132fw is successfully tested by our staff.
