I have a document with Multiline Text widgets with Font Size set to Auto.
When entering text, the font will get smaller as it it gets near the maximum width of the field until it reaches it smallest size. the text will then wrap when it reaches the maximum width of the text field.
I am able to reproduce this in your PdfEditorDemo app.
In other editors the font stays constant and automatically wrap until if fills the text box. It will then auto size to a smaller font to fit into the text field.
Is there a way to make the text stay at larger font and reduce the size of the font once multi line the text field is filled?
I am able to produce a sample document if you need.
AutoSize not working correctly in multi line Text Widget.
IntegraHarlan
Yuri
Re: AutoSize not working correctly in multi line Text Widget.
Yes, please send us a sample document so we can get quick understanding of the problem and provide you a feedback.
Hi Harlan,
In version 10.1.9.1 we have fixed the bug in algorithm, which calculates size of automatic font in multiline text field. Please use version 10.1.9.1 and let me know if you will have any question or problem.
