I'm not sure whether my question is in the correct forum, maybe I should have put it in the barcode forum, but anyway:
I'm looking for a way to split a pdf (created from a twain scan) that consists of several sections of varying and unknown length, seperated by a barcode.
The resulting sections of the pdf file I would like to save as individual image files (or pdf files) saved with a file name or on a location based on the information in the barcode at the top of the section.
Is this possible?
(To be clear: I don't expect any code examples (unless you really want to ) but just want to know whether this is at all possible and if so, what are the limitations)
split pdf into images where barcode is found
Re: split pdf into images where barcode is found
I need more info:
I need more info:
- Do you want to read barcode from PDF document? Am I right? This is possible using VintaSoftBarcode.NET SDK.
- Do you want split PDF document to many PDF documents? Am I right? This is possible using VintaSoftImaging.NET SDK + VintaSoftPDF.NET Plug-in (Reader + Writer).
Hi Alexander,
Thank you for your answer. I had read about the possibilities of splitting pdfs and reading barcodes, but I want don't want to split pdfs by whole pages, I would like to be able to save a part of a page. For example split 1 (a4) page into two files; one from the top to 10 centimetre, the second one from 10 centimetres from the top to the bottom.
The height of the sections I want to save has to be determined by the location of the barcodes.
Something like this.
Is that possible?
Is that possible?
This also possible.
Here are steps you need to do:
- Render image of PDF page
- Read barcodes on the image, barcode has information about its position on the image - using this information you can determine regions for splitting the image
- For each region: create a clone of image, crop cloned image, save cropped image
