PDF Information also in the XMP entry
oliverg
Post by oliverg » Tue Aug 28, 2012 1:00 pm
I have created some PDF with the Vintasoft PDF.dll now i have a question.
The Encoding is PDFA-1b.
i can write the PDF Infos Auhto Editor date without problem but Acrobat preflight says me it is not PDFA-1b conform.
And the error belong that the Information not in the XMP area for the PDF.
No i have the question is it possible with the momentary version Entrys i nthe XMP aerea to write. ?
Greetings
Olvier
Re: PDF Information also in the XMP entry
Post by Alex » Tue Aug 28, 2012 1:11 pm
Hello Oliver,
Please send more info about the issue: to support@vintasoft.com :
1. PDF document created with our SDK
2. Snippet of code which was used for creation of PDF document
Post by Alex » Fri Aug 31, 2012 8:54 am
Hello Oliver,
We have found a bug in encoder of PDF/A documents, the encoder creates PDF document not compatible with PDF/A specification if Author/Title/Subject/Keywords information is specified in PDF document.
Version with bug fix will be available on Monday.
Post by Alex » Wed Sep 05, 2012 8:39 am
Hello Oliver,
We have fixed incompatibility with PDF/A in PDF encoder in version 5.1.2.3 of VintaSoftImaging.NET SDK.
Thank you for your report.
