How To: Analyze the position of each word in the text
Posted: Sun Feb 24, 2013 9:08 pm
We are testing your "VintaSoftPDF.NET SDK" & "VintaSoftImaging.NET SDK" to get the following:
Explore each word in the text of PDF file for to know his position (X,Y,width and height -rounding box-)
If we have next portion of code:
We have been reviewing the help, not just find a way to do this easily with TextRegion, Subregion, LineSubregion, GetWordSubRegion ???
We don't understand who it works...
Can you help us ?
Thanks.
_fileStream.Position = 0
openFileThread.Start()
_isFirstOpenedPage = True
If _document.IsEncrypted Then
Text += " (SECURED)"
firstPage = 1
strNombreArchivoJPG = "PAG_" & Format(pageNo, "000") & ".jpg"
MsgBox(_document.Pages(pageNo).TextRegion.TextContent)
'we need to explore the position of each word in the text
Next
Can you help us ?
Thanks.
