How To: Analyze the position of each image
Posted: Sun Feb 24, 2013 9:18 pm
We are testing your "VintaSoftPDF.NET SDK" & "VintaSoftImaging.NET SDK" to get the following:
Explore each image in the PDF file to know his position (X,Y,width and height -rounding box-)
If we have next portion of code:
We have been reviewing the help, not just find a way to do this easily ???
We don't understand who it works...
Can you help us ?
Thanks.
_fileStream.Position = 0
openFileThread.Start()
_isFirstOpenedPage = True
If _document.IsEncrypted Then
Text += " (SECURED)"
firstPage = 1
For imageNo as integer = 1 to _document.Pages(pageNo).Images.Count - 1
MsgBox(_document.Pages(pageNo).Images(imageNo).Width)
MsgBox(_document.Pages(pageNo).Images(imageNo).Height)
_document.Pages(pageNo).Images(imageNo).GetImage.Save("c:\Page" & pageNo & " image" & imageNo & ".jpg")
Next
'we need to explore the position (x and y and rounding box) of each image in the PDF file
Next
Can you help us ?
Thanks.
