Your code is not correct.
First, you need create class that will represent the highlighted search result. Here is a code of such class:
class HightlightRectangle: IBoundedObject
Rectangle _rect;
public HightlightRectangle(Rectangle rect)
_rect = rect;
public Rectangle GetBoundingBox()
return _rect;
Next, you need create visual tool which will show highlighted objects:
class TextRegionHighlightTool : HighlightTool<HightlightRectangle>
Dictionary<VintasoftImage, TextRegion[]> _imageToRegions;
public TextRegionHighlightTool(Dictionary<VintasoftImage, TextRegion[]> imageToRegions)
_imageToRegions = imageToRegions;
protected override void OnActivate(EventArgs e)
base.OnActivate(e);
ImageViewer.FocusedIndexChanged += new EventHandler<FocusedIndexChangedEventArgs>(ImageViewer_FocusedIndexChanged);
ImageViewer.RenderingSettingsChanged += new EventHandler(ImageViewer_RenderingSettingsChanged);
UpdateItems();
protected override void OnDeactivate(EventArgs e)
ImageViewer.FocusedIndexChanged -= new EventHandler<FocusedIndexChangedEventArgs>(ImageViewer_FocusedIndexChanged);
ImageViewer.RenderingSettingsChanged -= new EventHandler(ImageViewer_RenderingSettingsChanged);
base.OnDeactivate(e);
private void UpdateItems()
VintasoftImage image = ImageViewer.Image;
TextRegion[] regions = _imageToRegions[image];
HightlightRectangle[] hightlightTextRegions = new HightlightRectangle[regions.Length];
PdfPage page = PdfViewerTool.GetPageFromImage(ImageViewer.Image);
for (int i = 0; i < hightlightTextRegions.Length; i++)
// region rectangle in PdfPage space
RectangleF rect = regions[i].Rectangle;
// convert PDF page space to Image space
rect = RectFromPdfPageSpaceToImageSpace(rect, page, image);
hightlightTextRegions[i] = new HightlightRectangle(Rectangle.Round(rect));
ColoredObjects<HightlightRectangle> objects = new ColoredObjects<HightlightRectangle>(hightlightTextRegions);
objects.Brush = new SolidBrush(Color.FromArgb(56, Color.Blue));
objects.Pen = null;
Items.Clear();
Items.Add(objects);
private RectangleF RectFromPdfPageSpaceToImageSpace(RectangleF rect, PdfPage page, VintasoftImage image)
PointF pt1 = new PointF(rect.X, rect.Y);
PointF pt2 = new PointF(rect.X + rect.Width, rect.Y + rect.Height);
page.UnitsToPixels(ref pt1, image.Resolution);
page.UnitsToPixels(ref pt2, image.Resolution);
rect.Width = pt2.X - pt1.X;
rect.Height = pt1.Y - pt2.Y;
rect.X = pt1.X;
rect.Y = pt1.Y - rect.Height;
return rect;
void ImageViewer_FocusedIndexChanged(object sender, FocusedIndexChangedEventArgs e)
UpdateItems();
void ImageViewer_RenderingSettingsChanged(object sender, EventArgs e)
UpdateItems();
Last, you need get all search results, create highlighted objects from results and show highlighted objects:
public void FindAllAndSelect(string text)
Dictionary<VintasoftImage, TextRegion[]> searchResults = FindAll(imageViewer1.Images, text);
TextRegionHighlightTool tool = new TextRegionHighlightTool(searchResults);
imageViewer1.VisualTool = tool;
// Search text in all pages.
private Dictionary<VintasoftImage, TextRegion[]> FindAll(ImageCollection images, string text)
Dictionary<VintasoftImage, TextRegion[]> results = new Dictionary<VintasoftImage, TextRegion[]>();
FindTextOptions options = new FindTextOptions();
options.MatchCase = false;
for (int i = 0; i < images.Count; i++)
PdfPage page = PdfVisualTool.GetPageFromImage(images[i]);
lock (page.Document)
List<TextRegion> regions = new List<TextRegion>();
int charIndex = 0;
while (true)
TextRegion region = page.TextRegion.FindText(text, ref charIndex, options);
charIndex += text.Length;
if (region != null)
regions.Add(region);
break;
results.Add(images[i], regions.ToArray());
return results;
We will simplify this code in version 7.0.
