Hi!
I'm evaluating VintaSoftPDF.
Could I set the XMP-Metadata by myself? Is it possible to set it for the document and separately for the page?
If so could you point me to a sample?
What about support for PDF/A-1a, PDF/A-2, PDF/A-3? Is it correct you currently support PDF/A-1b only?
Mike
XMP Metadata Support and PDF/A-1 to PDF/A-3
Re: XMP Metadata Support and PDF/A-1 to PDF/A-3
Hi Mike,
http://www.vintasoft.com/docs/vsimaging ... adata.html
You can get/set XMP-metadata of PDF page using the PdfPage.Metadata property:
You can get/set XMP-metadata of PDF document using the PdfDocument.Metadata property:Could I set the XMP-Metadata by myself? Is it possible to set it for the document and separately for the page?
SDK can create PDF/A-1b documents only.What about support for PDF/A-1a, PDF/A-2, PDF/A-3? Is it correct you currently support PDF/A-1b only?
Hi!
I want to bring PDF/A-3 up again.
Any news on supporting PDF/A-3?
There are many initiatives around the EU who try to get e-invoices with PDF files, which have XML-files attached to them and for this PDF/A-3 support is needed!
Mike
Mike
Hi Mike,
Do you need to create new PDF/A-3 compatible documents or do you need to convert any PDF document to PDF/A-3 format?
