Adding text annotation into PDF without mouse click
guillaume.corneau
Post by guillaume.corneau »
HI,
I search the way to add new text annotation in image viewer but without need to click on PDF
I currently able to add it but only with mouse click and drag to set the size
Thank you
Re: Adding text annotation into PDF without mouse click
Please read how to add PDF annotation to PDF page using code here:
guillaume.corneau
I want to add it into ImageViewer, not into PdfDocument
guillaume.corneau wrote: Thu Sep 17, 2020 6:29 pm I want to add it into ImageViewer, not into PdfDocument
Please read how to add Vintasoft annotation to PDF page using code here:
https://www.vintasoft.com/docs/vsimagin ... e_Pdf.html
Also please use AnnotationViewer class instead of ImageViewer.
guillaume.corneau
I found it
Just one question, when I try to change the DisplayMode I got this message "The license is not found."
Which kind of license I need to use this component ?
This the license I have now
VintaSoft Annotation .NET Plug-in - Site license
VintaSoft PDF .NET Plug-in (Reader) - Site license
VintaSoft PDF .NET Plug-in (Writer) - Site license
VintaSoft PDF .NET Plug-in (Visual Editor) - Site license
"The license is not found" error message means that you have not registered the SDK properly. Please read how to register the SDK in email with registration data.
If you will not be able to solve the problem, please send the support request to the support team at support@vintasoft.com. The SDK registration process cannot be discussed on the forums.
