WPF: Place a sticky note annotation on the image center in annotation viewer.
Code samples for VintaSoft Annotation .NET Plug-in. Here you can request a code sample.
This topic contains C# code snippet that shows how to place a sticky note annotation on the image center in a WPF annotation viewer.
using System;
using System.Windows;
using Microsoft.Win32;
using Vintasoft.Imaging;
using Vintasoft.Imaging.Utils;
namespace WpfApplication
    /// Main form.
    public partial class Window1 : Window
        /// Initializes a new instance of the <see cref="Window1"/> class.
        public Window1()
            InitializeComponent();
        /// Clears image collection of image viewer and
        /// adds image(s) to an image collection of image viewer.
        private void openButton_Click(object sender, RoutedEventArgs e)
            OpenFileDialog dialog = new OpenFileDialog();
            if (dialog.ShowDialog() == true)
                annotationViewer.Images.ClearAndDisposeItems();
                    annotationViewer.Images.Add(dialog.FileName);
                catch (Exception exc)
                    MessageBox.Show(exc.Message, "Error", MessageBoxButton.OK, MessageBoxImage.Error);
        /// Adds the sticky note annotation in the center of annotation viewer.
        private void addStickyNoteAnnotation_Click(object sender, RoutedEventArgs e)
            VintasoftImage image = annotationViewer.Image;
            if (image == null)
                return;
            // calculate location of annotation in pixels
            Point annotationLocation = new Point(image.Width / 2.0, image.Height / 2.0);
            // calculate size of annotation in pixels
            Size annotationSize = new Size(image.Width / 4.0, image.Height / 4.0);
            // create the annotation data
            AnnotationData data = CreateStickyNoteAnnotation(annotationLocation, annotationSize, image.Resolution);
            // add the annotation to the viewer
            annotationViewer.AnnotationDataCollection.Add(data);
            // select the annotation in the viewer
            annotationViewer.FocusedAnnotationData = data;
        /// Creates the sticky note annotation.
        /// <param name="location">The location of annotation in pixels.</param>
        /// <param name="size">The size of annotation in pixels.</param>
        /// <param name="imageResolution">The resolution of image.</param>
        private AnnotationData CreateStickyNoteAnnotation(Point location, Size size, Resolution imageResolution)
            StickyNoteAnnotationData data = new StickyNoteAnnotationData();
            // convert location from pixels to DIP
            double x = UnitOfMeasureConverter.ConvertToDeviceIndependentPixels(
                location.X, UnitOfMeasure.Pixels, imageResolution.Horizontal);
            double y = UnitOfMeasureConverter.ConvertToDeviceIndependentPixels(
                location.Y, UnitOfMeasure.Pixels, imageResolution.Vertical);
            data.Location = new System.Drawing.PointF((float)x, (float)y);
            // convert size from pixels to DIP
            double width = UnitOfMeasureConverter.ConvertToDeviceIndependentPixels(
                size.Width, UnitOfMeasure.Pixels, imageResolution.Horizontal);
            double height = UnitOfMeasureConverter.ConvertToDeviceIndependentPixels(
                size.Height, UnitOfMeasure.Pixels, imageResolution.Vertical);
            data.Size = new System.Drawing.SizeF((float)width, (float)height);
            return data;
        /// Raises the Closed event.
            base.OnClosed(e);
