Console: Enable the ultrasonic detection capability of Kodak scanner.
Posted: Fri Oct 06, 2017 10:52 am
Kodak scanners have many custom capabilities. Detailed information about all custom capabilities of Kodak scanners can be get from Kodak TWAIN Integrator Kit: http://www.kodakalaris.com/en/b2b/commo ... tion/twain.
Here is example that shows how to enable the ultrasonic detection capability of Kodak scanner:
using System;
namespace ConsoleApplication1
    class Program
                using (Vintasoft.Twain.DeviceManager deviceManager =
                    new Vintasoft.Twain.DeviceManager())
                    // open the device manager
                    deviceManager.Open();
                    // select the scanner using the standard device selection dialog
                    deviceManager.ShowDefaultDeviceSelectionDialog();
                    // get reference to the default device
                    Vintasoft.Twain.Device device = deviceManager.DefaultDevice;
                    // open the device
                    device.Open();
                    // if Kodak scanner is used
                    if (device.Info.ProductName.ToUpperInvariant().StartsWith("KODAK"))
                        // get the Kodak_UltrasonicSensitivity capability
                        Vintasoft.Twain.DeviceCapability kodakUltrasonicDetectionCap =
                            device.Capabilities.Find((ushort)Vintasoft.Twain.KodakDeviceCapabilityId.Kodak_UltrasonicSensitivity);
                        // if capability is supported
                        if (kodakUltrasonicDetectionCap != null)
                            // print current value of ultrasonic sensitivity
                            PrintKodakUltrasonicDetectionCurrentValue(kodakUltrasonicDetectionCap);
                            // change value of ultrasonic sensitivity to the High
                            kodakUltrasonicDetectionCap.SetValue(3);
                    // close the device
                    device.Close();
                    // close the device manager
                    deviceManager.Close();
            catch (Vintasoft.Twain.TwainException ex)
                Console.WriteLine("Error: " + ex.Message);
            Console.ReadLine();
        /// Prints the current value of Kodak ultrasonic detection capability.
        /// <param name="kodakUltrasonicDetectionCap">Kodak ultrasonic detection capability.</param>
        static void PrintKodakUltrasonicDetectionCurrentValue(
            Vintasoft.Twain.DeviceCapability kodakUltrasonicDetectionCap)
            Vintasoft.Twain.TwainValueContainerBase value =
                kodakUltrasonicDetectionCap.GetCurrentValue();
            Console.WriteLine("Current ultrasonic detection current value: {0}",
                ConvertKodakUltrasonicDetectionValueToString(value.GetAsInt32()));
        /// Converts the Kodak ultrasonic detection value to a string.
        /// <param name="value">Kodak ultrasonic detection value.</param>
        static string ConvertKodakUltrasonicDetectionValueToString(int value)
            switch (value)
                case 0:
                    return "Disabled";
                case 1:
                    return "Low";
                case 2:
                    return "Medium";
                case 3:
                    return "High";
                default:
