Read barcodes from an image if image data is stored in a byte array.
Post by Alex » Tue Aug 09, 2016 9:45 am
Here is an example that shows how to read barcodes from image if image data are stored in a byte array:
/// Reads barcodes from an image. Image data are stored in a byte array.
/// <param name="reader">The reader.</param>
/// <param name="width">The width.</param>
/// <param name="height">The height.</param>
/// <param name="stride">The stride.</param>
/// <param name="format">The format.</param>
/// <param name="pixelData">The pixel data.</param>
public static IBarcodeInfo[] ReadBarcodes(
    BarcodeReader reader,
    int width,
    int height,
    int stride,
    PixelFormat format,
    byte[] pixelData)
    // lock managed data
    GCHandle bitmapDataHandle = GCHandle.Alloc(pixelData, GCHandleType.Pinned);
    if (!bitmapDataHandle.IsAllocated)
        throw new InvalidOperationException();
    // get IntPtr to managed data
    IntPtr pixelDataPtr = Marshal.UnsafeAddrOfPinnedArrayElement(pixelData, 0);
        // read barcodes
        return ReadBarcodes(reader, width, height, stride, format, pixelDataPtr);
    finally
        // free GCHandle
        bitmapDataHandle.Free();
/// Reads barcodes from an image. Image data are stored in an unmanaged memory.
/// <param name="pixelDataScan0">The Scan0 pointer to pixel data.</param>
public static IBarcodeInfo[] ReadBarcodes(BarcodeReader reader, int width, int height, int stride, PixelFormat format, IntPtr pixelDataScan0)
    using (Bitmap bitmap = new Bitmap(width, height, stride, format, pixelDataScan0))
        // read barcodes
        return reader.ReadBarcodes(bitmap);
