Debugging options?
Peleus
Debugging options?
Post by Peleus »
Our scanning application is crashing on the VSTwain1.Acquire(); function in 32-bit Windows 7. The scanner is a Xerox DocuMate 262. I am compiling the version 6 library.
Everything functions on Windows XP with that scanner. I have also scanned in 64-bit Windows 7 using a different scanner.
I'm now at a loss as to how to debug this problem. Does the VintaSoftTwain.NET library have a debugging log file I can enable?
                    if (debug)
                        MessageBox.Show("Acquiring...");
                        VSTwain1.Acquire();
                    catch (Exception em)
                        if (debug)
                            MessageBox.Show(em.ToString());
                    if (debug)
                        MessageBox.Show("finished");
I see the first MessageBox but not the second. No excepetion is thrown either. The program just crashes. I get the following errors in Windows event viewer:
Faulting application name: ebillscan.exe, version: 1.0.3783.14170, time stamp: 0x4be96114
Faulting module name: KERNEL32.dll, version: 6.1.7600.16481, time stamp: 0x4b1e3897
Exception code: 0xc00000fd
Fault offset: 0x0004f1f4
Faulting process id: 0x1650
Faulting application start time: 0x01caf111eb57121e
Faulting application path: C:\ebillscan\ebillscan.exe
Faulting module path: C:\Windows\system32\KERNEL32.dll
Report Id: 3071847e-5d05-11df-a0ec-a4badbe64f0b
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: ebillscan.exe
P2: 1.0.3783.14170
P3: 4be96114
P4: KERNEL32.dll
P5: 6.1.7600.16481
P6: 4b1e3897
P7: c00000fd
P8: 0004f1f4
P9:
P10:
C:\Users\username\AppData\Local\Temp\WER5717.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\username\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_ebillscan.exe_92ffddf1df9c13c67ba52bfe47de3a3065645af7_12f95c55
Analysis symbol:
Rechecking for solution: 0
Report Status: 1
Thanks!
Ryan
Re: Debugging options?
Hello Ryan,
Yes, VintaSoftTwain.NET SDK has ability to create log-file.
Please do the following steps:
  • Run your application.
Peleus
Post by Peleus »
Here's the log file:
5/13/2010 2:33:01 PM ODS1
5/13/2010 2:33:01 PM ODS3 3
5/13/2010 2:33:01 PM ODS4 140
5/13/2010 2:33:02 PM ODS5 0
5/13/2010 2:33:02 PM ODS6 xerox documate 262
5/13/2010 2:33:02 PM 6.0.17.3
5/13/2010 2:33:02 PM ODS7 False
5/13/2010 2:33:02 PM PTW1 msg=0x1c (WM_ACTIVATEAPP) hwnd=0xc03dc wparam=0x1 lparam=0x480 result=0x0
5/13/2010 2:33:02 PM PTW90-5
5/13/2010 2:33:03 PM SetCap(257,5,4,2)
5/13/2010 2:33:03 PM SetCap result = 0
5/13/2010 2:33:03 PM SetCap(258,5,4,0)
5/13/2010 2:33:03 PM SetCap(4376,5,7,200)
5/13/2010 2:33:03 PM SetCap(4377,5,7,200)
5/13/2010 2:33:03 PM SetCap(1,5,1,-1)
5/13/2010 2:33:03 PM SetCap(4386,5,4,3)
5/13/2010 2:33:03 PM SetCap(4115,5,6,1)
5/13/2010 2:33:03 PM SetCap(4103,5,6,1)
5/13/2010 2:33:03 PM SetCap(4098,5,6,1)
5/13/2010 2:33:03 PM PTW1 msg=0x1c (WM_ACTIVATEAPP) hwnd=0xc03dc wparam=0x1 lparam=0x68c result=0x0
5/13/2010 2:33:03 PM PTW90-5
5/13/2010 2:33:04 PM ACQ1 False False
5/13/2010 2:33:04 PM ACQ2
5/13/2010 2:33:04 PM ACQ3
5/13/2010 2:33:04 PM ACQ5
5/13/2010 2:33:04 PM ACQ6
5/13/2010 2:33:04 PM ACQ7
5/13/2010 2:33:04 PM EDS3 False False
5/13/2010 2:33:04 PM EDS5 0
5/13/2010 2:33:04 PM ACQ8
5/13/2010 2:33:04 PM ACQ9
5/13/2010 2:33:04 PM PTW1 msg=0x1c (WM_ACTIVATEAPP) hwnd=0xc03dc wparam=0x1 lparam=0x68c result=0x0
5/13/2010 2:33:04 PM PTW90-5
5/13/2010 2:33:04 PM PTW1 msg=0xc059 hwnd=0xc03dc wparam=0x4130104 lparam=0x0 result=0x0
5/13/2010 2:33:04 PM PTW90-1 5
5/13/2010 2:33:04 PM PTW90-1-1
5/13/2010 2:33:04 PM PTW90-1-2
5/13/2010 2:33:04 PM TI1 Xerox DocuMate 262 False False False
5/13/2010 2:33:04 PM TI3 XRes=200 YRes=200 W=1700 H=2200 SPP=3 BPP=24, Planar=0, PT=2 Compr=0
5/13/2010 2:33:04 PM TI4 0 Native
5/13/2010 2:33:04 PM TI5
5/13/2010 2:33:04 PM DNT1
5/13/2010 2:33:04 PM DNT2
Thanks again,
Ryan
Hello Ryan,
Please try to use your scanner from another application, for example: What results do you have?
Peleus
Post by Peleus »
Sorry. I finally got around to this.
I used TWAIN Toolkit with no problems. It scanned perfectly.
I now have this problem on a second computer running Windows 7 Enterprise. As soon as aquire is called, my program crashes.
On a side note, if I run the program again and attempt to scan it says the scanner is in use. I then have to either disable/reenable the scanner in device manager or just unplug it and plug it back in.
Ryan
Hi Ryan,
Please send me a snippet of your code or application at support@vintasoft.com
Peleus
Post by Peleus »
Xerox released a new driver last week which has fixed the problem!
Thanks for your help,
Ryan
Hi Ryan,
