New features request for version 7.1 of VintaSoftTwain.NET
Posted: Tue Aug 10, 2010 2:16 pm
The following features are being considered for inclusion in version 7.1 of VintaSoftTwain.NET SDK:
  • Ability to access the file system of TWAIN device
  • Multi streaming (Single Document Multiple Images) support
  • WPF support
  • Ability to access raw data of acquired image
Re: New features request for version 7.1 of VintaSoftTwain.NET
Posted: Mon Sep 13, 2010 3:46 pm
by Almatrodi
Dear Alex
I suggest a method to save all images at once.
Posted: Thu Sep 16, 2010 8:40 am
Thank you for suggestion, we will add ability to save all images of collection at once in next version of SDK.
Posted: Thu Oct 14, 2010 5:26 pm
by dmitri_blinov
We would like to see the support for SSL client authentication while uploading images via HTTPS.
Posted: Fri Oct 15, 2010 7:45 am
Hello Dmitri,
SDK allows to upload acquired images to HTTP/HTTPS servers. What do you mean? Please explain.
Posted: Fri Oct 15, 2010 4:39 pm
by dmitri_blinov
Alexander,
It is not uncommon for SSL servers to require, for security reasons, some sort of authorization of its clients to permit requests.
If SSL server is configured to use SSL client authentication, this means, during SSL negotiation, client must provide server with some X509
certificate in order to prove its own identity. Without such a certificate the following exception is thrown "Could not create SSL/TLS secure channel".
Technically, the following code snippet can illustrate how this may be achieved in client code, I found this on some site, so this is not my code,
and it can contain errors, just in case.
HttpWebRequest httprq = (HttpWebRequest)HttpWebRequest.Create(uri);
string certificateName = "SoapProxy2";
X509Store store = new X509Store(StoreName.My, StoreLocation.CurrentUser);
store.Open(OpenFlags.ReadOnly);
X509Certificate2Collection certificates = store.Certificates.Find(X509FindType.FindBySubjectName, certificateName, true);
X509Certificate certificate = certificates[0];
httprq.ClientCertificates.Add(certificate);
httprq.Method = "POST";
httprq.ContentType = "text/xml; charset=utf-8";
httprq.ContentLength = 0;
HttpWebResponse httprp = (HttpWebResponse)httprq.GetResponse();
It would be great to expose some properties for HttpUpload component so that one can set store name, certificate name etc
for uploading images.
Best regards,
Dmitri
Alex wrote:Hello Dmitri,
Posted: Sun Oct 24, 2010 7:37 pm
by bharate.umesh
Hello Alexey,
Is this current version support wireless or remote scanner?
Umesh
Posted: Tue Oct 26, 2010 1:00 pm
Hello Umesh,
TWAIN specification describes work between application and TWAIN device (scanner).
You need to have TWAIN driver that can work with wireless/remote/network scanner if you want to work with such scanner.
Posted: Wed Dec 29, 2010 4:04 am
by lazyhog
Great job on VintaSoftTwain so far, Looking forward to WPF support.
Requests for V7.1:
1. Digital Stamp or Watermark, Just something simple to allow text to be stamped on the saved pages.
2. PDF Password, Allows a PDF password to be set when saving.
Cheers
Posted: Wed Dec 29, 2010 4:35 pm
Thank you for good words about our work.
Please use VintaSoftImaging.NET SDK + VintaSoftAnnotation.NET Plug-in if you want to annotate images acquired from scanner.
We will add this feature in VintaSoftPDF.NET Plug-in.
