[Citrix] Error at opening the Data Source
vagtler
Post by vagtler » Fri Aug 27, 2010 7:51 pm
we already sent an email yesterday to support@vintasoft.com but with no avail.
We have big problems scanning with VintaSoftTwain.NET SDK 6.0.5.1 under Citrix.
We always(!) get System.ApplicationException: Error communicating with the scanner device - Error at opening the Data Source. ---> Vintasoft.Twain.TwainException: Error at opening the Data Source.
at Vintasoft.Twain.VSTwain.OpenDataSource() messages
We just slightly modified your SimpleDemo of Visual Studio 2008 to select a TwainDLL.
    public partial class Form1 : Form
        public Form1() {
            var tgs = new TwainGlobalSettings();
            tgs.Register("[our company name]", "[our registered user email address]", “[our license number]”);
            InitializeComponent();
            twainDllFilenameEdit.Text = VSTwain1.TwainDllPath;
        private void button1_Click(object sender, EventArgs e) {
            try {
                VSTwain1.StartDevice();
                if (VSTwain1.SelectSource()) {
                    VSTwain1.ShowUI = true;
                    VSTwain1.DisableAfterAcquire = false;
                    VSTwain1.Acquire();
            catch (Vintasoft.Twain.TwainException ex) {
                MessageBox.Show(ex.Message);
        private void button2_Click(object sender, EventArgs e) {
            try {
                    VSTwain1.ShowUI = false;
                    VSTwain1.DisableAfterAcquire = true;
                    VSTwain1.OpenDataSource();
                    VSTwain1.UnitOfMeasure = Vintasoft.Twain.UnitOfMeasure.Inches;
                    VSTwain1.PixelType = Vintasoft.Twain.PixelType.RGB;
                    VSTwain1.Acquire();
        private void VSTwain1_ImageAcquired(object sender, EventArgs e) {
            if (pictureBox1.Image != null) {
                pictureBox1.Image.Dispose();
                pictureBox1.Image = null;
            pictureBox1.Image = VSTwain1.GetCurrentImage();
        private void VSTwain1_ScanCompleted(object sender, EventArgs e) {
            if (VSTwain1.ErrorCode != Vintasoft.Twain.ErrorCode.None)
                MessageBox.Show(VSTwain1.ErrorString);
        private void twainDllFilenameSelectButton_Click(object sender, EventArgs e) {
            openFileDialog1.InitialDirectory = Path.GetFullPath(VSTwain1.TwainDllPath);
            openFileDialog1.FileName = String.Empty;
            if (openFileDialog1.ShowDialog() == DialogResult.OK) {
                VSTwain1.TwainDllPath = openFileDialog1.FileName;
We followed the guidelines given in the articles http://support.citrix.com/article/CTX123981 and http://support.citrix.com/article/CTX107409
Regarding to http://support.citrix.com/article/CTX107411: “If this issue is only happening with a 3rd party/custom application, obtain input from the application vendor to determine the process they take to acquire images with TWAIN.”
Scanning with other applications works without problems.
This is mission critical for us! Do you have any ideas?
Greetings
Robert
Re: [Citrix] Error at opening the Data Source
Post by Alex » Mon Aug 30, 2010 1:45 pm
Hello Robert,
Please try to use version 7.0 of SDK and let me know results.
vagtler
Post by vagtler » Wed Sep 01, 2010 2:01 pm
Hi Alexander,
we upgraded to 7.0.1 and the problems are gone... ;)
Thanks!
Robert
