Color Dropout
Posted: Thu May 31, 2012 4:02 pm
by Krishna
According to Twain specifications, ICAP_FILTER can be used to dropout certain colors. But VSTwain DeviceCapability doesnt seem to support this particular Capability. Is there any way I can dropout colors(green in my case) using VSTwain? ( we only purchased the VintaSoftTwain.net SDK and not the imaging one).
Krishna
Re: Color Dropout
Posted: Sat Jun 02, 2012 9:53 am
Hello Krishna,
First, you need check that ICAP_FILTER capability is supported by your scanner:
DeviceCapability filterCap = device.Capabilities.Find(DeviceCapabilityId.IFilter);
if (filterCap == null)
    throw new ApplicationException("ICAP_FILTER capability is not supported by device.");
Next, you need get supported values of capability:
DeviceCapabilityValueBase filterCapValue = filterCap.GetValue();
switch (filterCapValue.ContainerType)
    case DeviceCapabilityContainerType.Array:
        ArrayDeviceCapabilityValue filterCapValueAsArray = (ArrayDeviceCapabilityValue)filterCapValue;
        // get supported values of capability
        break;
    case DeviceCapabilityContainerType.Enum:
        EnumDeviceCapabilityValue filterCapValueAsEnum = (EnumDeviceCapabilityValue)filterCapValue;
        break;
Finally, you need set value of capability:
filterCap.SetValue(X);
Re: Color Dropout
Posted: Wed Jun 06, 2012 12:13 pm
by Krishna
Thanks a lot for your reply. Sorry I forgot to mention that we are using Version 6.0.2.1 so I could not check your solution. Can you please give me equivalent code for Version 6?
Regards,
Krishna
Re: Color Dropout
Posted: Thu Jun 07, 2012 1:09 pm
Hello Krishna,
Here is the code for version 6.0.
VSTwain1.Capability = (int)Vintasoft.Twain.DeviceCapability.IFilter;
if (!VSTwain1.IsCapSupported())
VSTwain1.GetCap();
switch (VSTwain1.CapType)
    case CapType.Array:
        break;
    case CapType.Enum:
        break;
VSTwain1.CapType = CapType.OneValue;
VSTwain1.CapValue = X;
VSTwain1.SetCap();
Re: Color Dropout
Posted: Thu Jun 07, 2012 1:30 pm
by Krishna
Thanks a lot Alex. This worked brilliantly. Although I had to guess the Green value to be '1' as the CapType (0 for red and 2 for blue I think) for this capability is OneValue and I could not get all the valid values.
I had a Fujitsu fi-5530C2 which seems to support this capability and Kodak I1120 scanner which doesnt support it. Is there anyway to get the Capabilities of a particular scanner (before purchasing it) so that we can recommend the client which scanner to purchase incase they need to dropout any particular color?
Re: Color Dropout
Posted: Thu Jun 07, 2012 3:46 pm
Here is a list of available values for ICAP_FILTER capability:
  • RED - 0
  • GREEN - 1
  • BLUE - 2
  • NONE - 3
  • WHITE - 4
  • CYAN - 5
  • MAGENTA - 6
  • YELLOW - 7
  • BLACK - 8
Most of photo scanners can dropout colors.
