It is possible to detect document size after scanning or durring scan?
I use microtek ScanMaker 5950 Twain 1.9 scanner.
Re: detect document size after scanning
What do you mean as "detect document size after scanning"? Do you want to detect document border automatically? If yes, you can use the DetectImageBorder method.
Here is a snippet of code:
Please read more info in the documentation.
Imports VintaSoft.Twain
Private Sub ProcessImageButton_Click(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles BProcessImage.Click
Try
VSTwain1.DespeckleImage(imageNum, 8, 25, 30, 400)
VSTwain1.DeskewImage(imageNum,BorderColor.AutoDetect, 5, 5)
VSTwain1.DetectImageBorder(imageNum, 5, 5, 5)
If Not PictureBox1.Image Is Nothing Then
PictureBox1.Image.Dispose()
PictureBox1.Image = Nothing
LabelImageNum.Text = "Image " + CStr(imageNum) + _
" (" + CStr(VSTwain1.GetImageWidth(imageNum)) + _
" x " + CStr(VSTwain1.GetImageHeight(imageNum)) + _
" x " + CStr(VSTwain1.GetImageBPP(imageNum)) + " bpp)"
PictureBox1.Image = VSTwain1.GetImage(imageNum)
Catch ex As ImagingException
MsgBox ex.Message
End Try
End Sub
Private Sub VSTwain1_ProgressChanged(ByVal sender As Object, _
ByVal e As VintaSoft.Twain.ProgressChangedEventArgs) _
Handles VSTwain1.ProgressChanged
Select Case e.Action
Case Action.Deskew
txtAction.Text = "Deskewing..."
Case Action.Despecle
txtAction.Text = "Despeckling..."
Case Action.BorderDetection
txtAction.Text = "Border detecting..."
Case Action.Rotation
txtAction.Text = "Rotating..."
Case Action.ImageScan
txtAction.Text = "Image scan..."
End Select
progressBar1.Value = e.PercentComplete
e.Interrupt = bFinishFlag
End Sub
