SET ADF AUTOFEED
ATSATS
SET ADF AUTOFEED
Post by ATSATS »
I have a Kodak i260 scanner and have the following error when I try to use the ADF mode, and set
'VSTwain1.AutoFeed = True
scanner generates an error: "Error Capability"
below my code ...
VSTwain1.StartDevice()
'VSTwain1.SelectSource()
VSTwain1.ShowUI = False
'VSTwain1.DisableAfterAcquire = True
VSTwain1.MaxImages = 1
VSTwain1.AutoCleanBuffer = True
VSTwain1.OpenDataSource()
VSTwain1.UnitOfMeasure = UnitOfMeasure.Inches
VSTwain1.PixelType = PixelType.BW
VSTwain1.Resolution = 200
VSTwain1.TiffMultiPage = False
VSTwain1.TiffCompression = TiffCompression.Auto
If VSTwain1.Duplex <> DuplexMode.None Then
VSTwain1.DuplexEnabled = False 'ABILITA il DUPLEX
If VSTwain1.FeederPresent Then
VSTwain1.FeederEnabled = True
'VSTwain1.AutoFeed = True 'SCANSIONE CONTINUA'
If VSTwain1.FeederLoaded Then
VSTwain1.Acquire()
THANK YOU
Re: SET ADF AUTOFEED
I think scanner does not support CAP_AUTOFEED capability. You can see a list of capabilities supported by the scanner in our Advanced demo - run the demo and press the "Get Source info" button.
