What is Modal UI?
Almatrodi
What is Modal UI?
Post by Almatrodi » Sun Jan 18, 2009 2:21 am
I tried to set it on and off to see the different. But, I couldn't know what is its purpose.
May anyone explain it to me?
Re: What is Modal UI?
Post by Alex » Tue Jan 20, 2009 5:27 pm
What driver for your device do you use? WIA drivers does not allow to disable UI.
Almatrodi
Post by Almatrodi » Wed Jan 21, 2009 1:42 am
It is TWAIN.
Post by Alex » Wed Jan 21, 2009 9:14 am
Please send a message with description of your problem to our support team at support@vintasoft.com. Message must contain the following information:
1. Name of your scanner
2. Snippet of your code
2. Screenshot which demonstrates the problem
Almatrodi
Post by Almatrodi » Thu Jan 22, 2009 12:14 pm
Dear Alex
It is not a problem. But I want to know what is it. I am new to Imaging and scanning. So, I want just to know what is Modal UI.
Post by Alex » Thu Jan 22, 2009 2:44 pm
Sorry, I was not attentive and have misunderstood your question. You are asking about modal UI, not about enabling/disabling UI.
About modal UI: User Interface will be shown as a modal dialog if value of the ModaulUI property is set to True and as non modal dialog otherwise. Sometimes you should set the value of the Parent property before using the ModalUI property.
Almatrodi
Post by Almatrodi » Thu Jan 22, 2009 11:52 pm
Thanks very much for you help.
