Version 12.4 of VintaSoft Imaging .NET SDK has been released.
The new version 12.4 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 12.4:
  • .NET development
    • Added the decoder for NDPI and VMS (Hamamatsu) image files.
    • Added multithreading in algorithm that decodes TIFF image with JPEG compression - this change significantly increased the algorithm performance.
    • Added the ability to use fast scarolling of images in image viewer.
    • Demo applications:
      • Added the ability to view NDPI and VMS (Hamamatsu) image files in LargeImageViewerDemo, ImagingDemo and WpfImagingDemo demo projects.
    • Fixed several non-critical bugs.
What's new in VintaSoft Office .NET Plug-in 4.4:
  • .NET development
    • Added the ability to convert PDF document to a DOCX document.
    • Added the ability to open secured DOCX and XLSX documents.
    • Added the support for new types of charts: Bubble, Stock, Combined, 3D Bubble, 3D Line, 3D Column, 3D Area, 3D Stacked Area.
    • Created WinForms-control SpreadsheetDocumentEditorControl and WPF-control WpfSpreadsheetDocumentEditorControl - each control is a fully featured XLSX document editor.
      • Significantly simplified code of SpreadsheetEditorDemo/WpfSpreadsheetEditorDemo project because project now uses the SpreadsheetDocumentEditorControl control.
  • Web development
    • Added the ability to open secured DOCX and XLSX documents in web document viewer.
What's new in VintaSoft PDF .NET Plug-in 9.4:
  • .NET development
    • Now PDF/A-1b converter can convert PDF documents, which contain OpenType fonts.
    • Improved the algorithm of PDF/A converter.
    • Improved the algorithm that allows to remove unnecessary content from a PDF document (PdfDocumentCleanupCommand class).
    • Improved the algorithm that compresses PDF document (PdfDocumentCompressorCommand class).
    • Significantly reduced the memory usage when rendering a PDF page that contains a large amount of vector content.
    • Fixed the bug in algorithm that decodes LZW data.
    • Fixed the bug in algorithm that renders FreeFormGouraudShadedTriangleMesh pattern.
    • Fixed several minor bugs in algorithm that renders a PDF page.
What's new in VintaSoft Annotation .NET Plug-in 12.4:
  • Web development
    • Now the visual tool WebMagnifierToolJS allows to magnify image with annotations. Previously the visual tool was able to magnify image only.
    • Added properties LoadAnnotationsOnlyForDisplayedImages and LoadAnnotationsOnlyForVisibleImages to the WebAnnotationViewerJS class.
What's new in VintaSoft JBIG2 .NET Plug-in 7.4:
  • .NET development
    • Increased the performance of JBIG2 decoder up to 20%.
    • Increased the performance of JBIG2 encoder up to 15%.
    • Fixed the bug in algorithm that decodes data of JBIG2 image.
What's new in VintaSoft JPEG2000 .NET Plug-in 8.4:
  • .NET development
    • Increased the performance of JPEG2000 decoder up to 15%.
    • Improved the algorithm that decodes JPEG2000 file, which does not conform to JPEG2000 standard.
    • Fixed the bug in algorithm that decodes data of JPEG2000 image.
What's new in VintaSoft OCR .NET Plug-in 7.4:
  • .NET development
    • The used Tesseract OCR engine has been updated to version 5.3.4.
What's new in VintaSoft DICOM .NET Plug-in 5.4:
  • .NET development
    • Updated DICOM types and metadata to comply with DICOM 2023 specification.
Version 12.4.1.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the smoothness of scrolling for large images in WinForms/WPF image viewer.
  • Web development
    • Improved the algorithm that initializes the annotation list panel in web document viewer.
  • .NET development
    • Fixed the bugs in the algorithm that renders chart in spreadsheet editor control.
    • Fixed the bugs in the algorithm that edit chart in spreadsheet editor control.
