Problem on Windows 7 64 bit machines
Abacus
Post by Abacus »
Win 7 64 bit machines return "Library not initialized" error on start.
TwainAdvanced.exe in "C:\Program Files (x86)\VintaSoft\VSTwain.NET.6_0\Bin\v2.0\64-bit" folder works properly but when I try TwainAdvanced sample in Visual Studio i get the error.
Did I have to do anything else for 64 bit machine?
D.
Abacus
Re: Problem on Windows 7 64 bit machines
Post by Abacus »
Update:
This error is gone if compiled as x86. Now works but I do not see the WIA option that I see on a 32 bit machine.
Also only works if scanner UI is suppressed.
D.
Yes, you should compile your project in x86 mode on 64 bit systems.
I think your device does not have WIA driver for 64 bit systems.
Please send information about your device, snippet of your code and log-file to support@vintasoft.com and we will try to fix the problem.
