Library not initialized
BillG
Post by BillG » Thu Sep 02, 2010 1:20 am
I am running 32 bit version of VS 2008 on Windows 7 64 bit machine. I am still using the Vintasoft 5 sdk because I don't want to update the client until next week. When I run the software on my development machine and try to scan I get "library not initalized". The error occurs on the vsTwain1.StartDevice() line. Here is the code snippet. It worked fine prior to moving to the Windows 7 64 bit machine on a Vista 32 bit machine. I am using the net 2.0 86x vstwain.dll.
           vsTwain1.StartDevice();
                    vsTwain1.ShowUI = false;
                    if (vsTwain1.SelectSource())
                        vsTwain1.MaxImages = 1;
                        vsTwain1.OpenDataSource();
                        vsTwain1.PixelType = PixelType.BW;
                        if (vsTwain1.FeederPresent)
                            string dirPath = "q:\\EmployerDocuments\\" + myController.CurrentEmployer.Office + "\\";
                            string dateString = DateTime.Now.Year.ToString() + DateTime.Now.Month.ToString("00") + DateTime.Now.Day.ToString("00");
                            RelatedDocumentType rdType = (RelatedDocumentType)ScanItemTypeComboBox.SelectedItem;
                            string docDesc = rdType.DocumentTypeDesc;
                            string filePath = dirPath+myController.CurrentEmployer.EmployerId.ToString() + docDesc + dateString + ".pdf";
                            Int32 numOfPages = Int32.Parse(NumberOfPagesTextBox.Value.ToString());
                            vsTwain1.AutoFeed = true;
                            vsTwain1.XferCount = 1;
                            vsTwain1.PdfMultiPage = true;
                            if (vsTwain1.FeederLoaded)
                                vsTwain1.ShowIndicators = true;
                                while (vsTwain1.AcquireModal())
                                        if (pictureBox1.Image != null)
                                            pictureBox1.Dispose();
                                            pictureBox1.Image = null;
                                        pictureBox1.Image = vsTwain1.GetCurrentImage();
                                        vsTwain1.SaveImage(0, filePath);
                                    catch (TwainException ex)
                                        if (vsTwain1.ErrorCode != Vintasoft.Twain.ErrorCode.None)
                                            MessageBox.Show(vsTwain1.ErrorString);
                                            MessageBox.Show(ex.Message);
                                Int32 docTypeId = Int32.Parse(rdType.DocumentTypeId.ToString());
                                myController.SaveScannedRecord(docTypeId, filePath, DescriptionTextBox.Text.ToString(), numOfPages);
                                vsTwain1.StopDevice();
                    DescriptionTextBox.Text = string.Empty;
                    NumberOfPagesTextBox.Value = 1;
                    PopulateDocumentsGrid();
                    this.Cursor = Cursors.Arrow;
                catch (Exception ex)
Re: Library not initialized
Post by Alex » Thu Sep 02, 2010 8:31 am
Hello Bill,
You can compile your application with version 6.0 and earlier of VintaSoftTwain.NET SDK in "Any CPU" mode and your application will:
  • work in x32 systems with TWAIN_32.DLL or TWAINDSM.DLL (x32)
  • NOT work in x64 systems
You can compile your application with version 6.0 and earlier of VintaSoftTwain.NET SDK in "x86" (WOW) mode and your application will:
  • work in x64 systems with TWAIN_32.DLL or TWAINDSM.DLL (x32)
You can compile your application with version 6.0 and earlier of VintaSoftTwain.NET SDK in "x64" mode and your application will:
  • NOT work in x32 systems
You can compile your application with version 7.0 of VintaSoftTwain.NET SDK in "Any CPU" mode and your application will:
  • work in x64 systems with TWAINDSM.DLL (x64)
You can compile your application with version 7.0 of VintaSoftTwain.NET SDK in "x86" (WOW) mode and your application will:
You can compile your application with version 7.0 of VintaSoftTwain.NET SDK in "x64" mode and your application will:
We recommend use "x86" mode because all scanners have x32 TWAIN drivers but only new and professional scanners have native x64 TWAIN drivers.
BillG
Post by BillG » Thu Sep 02, 2010 4:46 pm
I am using the 32 bit version of Visual Studio 2008 and I only have the choice of any cpu. How do I set it up to use 86x (WOW) mode?
Bill
Post by Alex » Fri Sep 03, 2010 8:11 am
You can set the platform target property to 'X86' for your VB or C# projects as follows:
For C# Projects:
  • Right click the project in the solution explorer and open 'properties'
  • Choose the Build tab
  • Set the Platform Target property to 'X86'
For VB Projects:
  • Choose the Compile tab
  • Press the Advanced Compile Options... button
  • Set the Target CPU property to 'X86'
