Scanning multiple pages
Questions, comments and suggestions concerning VintaSoftTwain.NET SDK.
Postby srikanthgaddala » Fri Sep 03, 2010 10:30 am
Hi All,
I have a requirement that i need to scan a batch(probably more than 10 pages) but i want to save it as a single pdf document.
Example if i have scanned 10 pages from my scanner i need to save it as a sample.pdf where this sample.pdf contains those 10 pages in it.
Please help me to solve this.Thank you in advance..
if possible send me the code.
Srikanth.G
srikanthgaddala
Re: Scanning multiple pages
Postby Alex » Fri Sep 03, 2010 10:41 am
Hello Srikanth,
Please read this FAQ:
http://www.vintasoft.com/vstwain-dotnet-faq.html#Programming_AdfWithoutUi
Postby srikanthgaddala » Fri Sep 03, 2010 11:10 am
Really thanks for your quick reply.
but my case is i need to save it as a pdf file.
let me explain you my requirement clearly.I have a C# application.when i click on scan button it should scan the multiple pages and should be saved as a single pdf file.Like i have explained in the previous post.
Thanks in advance
Sincerely ......
Srikanth Gaddala
srikanthgaddala
Postby Alex » Fri Sep 03, 2010 11:19 am
Just change extension in filename from ".tif" to ".pdf" and acquired images will be saved in PDF document.
Code from FAQ:
e.Image.Save("c:\multipage.tif")
New code:
e.Image.Save("c:\multipage.pdf")
Postby srikanthgaddala » Fri Sep 03, 2010 11:30 am
Thanks again Alex,
where can i find this DeviceManager and Device classes.i am getting the errors.under which name space they will be available?
Sincerely ,,,,,
Srikanth Gaddala
srikanthgaddala
Postby Alex » Fri Sep 03, 2010 11:45 am
You need to use version 7.0 of VintaSoftTwain.NET SDK.
Postby srikanthgaddala » Fri Sep 03, 2010 12:02 pm
yeah thanks Alex,
i found it.....
thank you very much..
sincerely..
Srikanth Gaddala
srikanthgaddala
Return to VintaSoftTwain.NET SDK Discussions
Users browsing this forum: Google [Bot] and 0 guests
cron
