IndexOutOfBoundsException with german umlauts
Document Partner
Post by Document Partner » Thu Sep 08, 2011 3:19 pm
I get an exception " Index was outside the bounds of the array." when trying to encode an Aztec symbol with german umlauts.
Here is the C# code I am using:
      var barcodeWriter = new Vintasoft.Barcode.BarcodeWriter ();
      barcodeWriter.Settings.Barcode = Vintasoft.Barcode.BarcodeType.Aztec;
      barcodeWriter.Settings.ProcessSpecialSymbols = true;
      var valueItems = new List<ValueItemBase> ();
      valueItems.Add (new TextValueItem (@"German
  AÄBCDEFGHIJKLMNOÖPQRSßTUÜVWXYZ
  aäbcdefghijklmnoöpqrsßtuüvwxyz"));
      barcodeWriter.Settings.ValueItems = valueItems.ToArray ();
      var outputImage = barcodeWriter.GetBarcodeAsBitmap ();
      return outputImage;
kind regards,
Roman Brandstetter
Yuri
Re: IndexOutOfBoundsException with german umlauts
Post by Yuri » Fri Sep 09, 2011 9:50 am
TextValueItem may contain only symbols which are allowed for encoding in text mode.
The symbols like Ä, Ö, Ü and ß should be encoded in binary mode.
Utilize automatic selection of encoding mode by setting barcodeWriter.Settings.Value property at necessary value.
The following code illustrate how your text is automatically devided on 17 items for its correct encoding further:
var barcodeWriter = new Vintasoft.Barcode.BarcodeWriter();
barcodeWriter.Settings.Value =
"GermanAÄBCDEFGHIJKLMNOÖPQRSßTUÜVWXYZaäbcdefghijklmnoöpqrsßtuüvwxyz";
var outputImage = barcodeWriter.GetBarcodeAsBitmap();
// TEST (read)
var barcodeReader = new BarcodeReader();
barcodeReader.Settings.ScanBarcodeTypes = barcodeWriter.Settings.Barcode;
IBarcodeInfo barcodeInfo = barcodeReader.ReadBarcodes(outputImage)[0];
if (barcodeWriter.Settings.Value != barcodeInfo.Value)
    throw new ArgumentException();
foreach (ValueItemBase valueItem in barcodeInfo.ValueItems)
    Console.WriteLine(string.Format("[{0}] {1}", valueItem.GetType().Name,
valueItem));
Sincerely, Yuri
Document Partner
Post by Document Partner » Fri Sep 09, 2011 10:15 am
Thanks for the info. The Code is working now.
kind regards,
Roman
