SaveSettings()
snksoft
SaveSettings()
Post by snksoft » Sat Feb 11, 2012 5:01 pm
My application queries
_device.Capabilities.Find(DeviceCapabilityId.CustomDsData)
. If device has this feature, application continue with this code,
AddHandler _device.UserInterfaceClosed, AddressOf _device_UserInterfaceClosed
 _device.Setup()
Private Sub _device_UserInterfaceClosed(sender As Object, e As EventArgs)
        Dim filePath As String = System.IO.Path.Combine(System.IO.Path.GetTempPath(), Guid.NewGuid.ToString())
        Using dummyFileStream As FileStream = System.IO.File.Open(filePath, IO.FileMode.CreateNew)
            _device.SaveSettings(dummyFileStream)
            _device.SaveSettings()
        End Using
End Sub
But I get "Cannot get profile of device." exception.
Device is Canon ImageFormula DR-C125
Re: SaveSettings()
Post by Alex » Mon Feb 20, 2012 11:22 am
Thank you for your message.
We have fixed a bug in version 8.0.4.1 and since this version your code will work correctly.
