Programmatically delete annotation
iansml
Post by iansml » Wed May 06, 2009 1:52 pm
Is there any way I can programmatically remove an annotation? I am able to hide it using:
imageViewer1.SelectedAnnotation.Visible = false;
but it is still present in the ImageViewer.Annotations collection. I want it to be removed completely (like when I select an annotation and delete it manually using the delete key).
Re: Programmatically delete annotation
Post by Alex » Wed May 06, 2009 3:00 pm
Hi Ian,
Thank you for your message. You can use the Remove method of the AnnotationCollection class. Here is an example:
AnnotationBase annoToRemove = annotationViewer1.Annotations[imageIndex][indexOfAnnoToRemove];
annotationViewer1.Annotations[imageIndex].RemoveAt(annoToRemove);
We will redefine the RemoveAt method of the AnnotationCollection class in next version of library and it will work correctly.
