How To: Analyze the position of each image
tjimenez
Post by tjimenez » Sun Feb 24, 2013 9:18 pm
We are testing your "VintaSoftPDF.NET SDK" & "VintaSoftImaging.NET SDK" to get the following:
Explore each image in the PDF file to know his position (X,Y,width and height -rounding box-)
If we have next portion of code:
_fileStream.Position = 0
openFileThread.Start()
_isFirstOpenedPage = True
If _document.IsEncrypted Then
Text += " (SECURED)"
firstPage = 1
    For imageNo as integer = 1 to _document.Pages(pageNo).Images.Count - 1
            MsgBox(_document.Pages(pageNo).Images(imageNo).Width)
            MsgBox(_document.Pages(pageNo).Images(imageNo).Height)
           _document.Pages(pageNo).Images(imageNo).GetImage.Save("c:\Page" & pageNo & " image" & imageNo & ".jpg")
    Next
'we need to explore the position (x and y and rounding box) of each image in the PDF file
Next
We have been reviewing the help, not just find a way to do this easily ???
We don't understand who it works...
Can you help us ?
Thanks.
Re: How To: Analyze the position of each image
Post by Alex » Mon Feb 25, 2013 9:38 am
PDF document contains image resources. You need to use the PdfDocument.Images property if you want to get information about image resources used in PDF document.
PdfDocument.Images property returns a collection of the PdfImageResource objects. The PdfImageResource class contains information about image size.
Each image resource can be used several times, for example, the same image resource can be used on several PDF pages. You need to use the PdfPage.ImageExtractor property if you want to get information about image resources used in PDF page.
PdfPage.ImageExtractor property returns an instance of the ImageExtractor class. The ImageExtractor class has the Images property. ImageExtractor.Images property returns an array of the ContentImage objects. The ContentImage class contains information about image size and position of the image on the PDF page.
Here is an example that demonstrates how to get information about position and size of image resources for each PDF page.
Imports System.Drawing
Imports Vintasoft.Pdf
Imports Vintasoft.Pdf.Tree
Imports Vintasoft.Pdf.Content.ImageExtraction
Module Module1
    Sub Main()
        ' open existing PDF document
        Dim pdfDocument As New PdfDocument("d:\PdfTest.pdf")
        ' for each PDF page
        For i As Integer = 0 To pdfDocument.Pages.Count - 1
            Console.WriteLine(String.Format("PDF page {0}", i))
            GetInfoAboutImageResourcesOfPdfPage(pdfDocument.Pages(i))
        Next
        ' free resources
        pdfDocument.Dispose()
        Console.ReadLine()
    End Sub
    Public Sub GetInfoAboutImageResourcesOfPdfPage(ByVal page As PdfPage)
        Dim contentImages As ContentImage() = page.ImageExtractor.Images
        For i As Integer = 0 To contentImages.Length - 1
            Console.WriteLine(String.Format("  Image X={0}, Y={1}, Width={2}, Height={3}", _
                                            contentImages(i).Region.LeftTop.X, _
                                            contentImages(i).Region.LeftTop.Y, _
                                            contentImages(i).Region.Bounds.Width, _
                                            contentImages(i).Region.Bounds.Height))
        Next
    End Sub
End Module
tjimenez
Post by tjimenez » Mon Feb 25, 2013 3:12 pm
Okay, good explanation.
Thank you very much.
