Version 7.2 of VintaSoftImaging.NET SDK has been released.
  • Created RAW files decoder with the following functionality:
    • Supported RAW file formats: DNG, NEF, CR2, CRW, NRW.
    • The ability to obtain thumbnail, image for preview or original image.
    • The ability to obtain original image with or without interpolation. Supported are bilinear, gradient and adaptive interpolations.
    • The ability to apply white balance color correction to the original image. Supported are automatic white balance, camera white balance and user-defined white balance.
    • The ability to get image metadata.
  • Added the decoding support for 2-bit BMP format in ICO files.
  • Added the ability to disable the rendering settings management of image viewer.
  • Multi Webcam Demo created, which demonstrates the ability to display video from several cameras on one form.
  • Raw Image Viewer Demo created, which allows to preview all images from a RAW file (thumbnail, image for preview, original image). Original image can be obtained with or without interpolation and can be a subject for white balance color correction.
  • Improved support of transparency in PDF documents:
    • Added support for SoftMask parameter of graphical state.
    • Added support of Transparency Group XObjects.
  • Improved the drawing quality of rotated composite images in PDF.
  • Fixed bugs in parsers of Type1 and CFF fonts.
  • Added the ability to edit tiles of JPEG2000 image.
  • Optimized the memory usage in JPEG2000 encoder.
  • JPEG2000 encoder is accelerated up to 25%.
What's new in this version of VintaSoftDocCleanup.NET Plug-in:
  • Created new document cleanup commands:
    • HalftoneRecognitionCommand - seeks for halftone regions on the image.
    • HalftoneRemovalCommand - removes halftones from the image.
    • RestoreTextFromHalftoneCommand - restores text in halftone regions on the image.
What's new in this version of VintaSoftOCR.NET Plug-in:
  • The used Tesseract OCR Engine upgraded to version 3.02:
    • Improved OCR quality.
    • New supported languages: Afrikaans, Albanian, Azerbaijani, Belarusian, Bengali, Estonian, Basque, Frankish, Galician, Croatian, Icelandic, Malayalam, Macedonian, Maltese, Malay, Swahili, Tamil, Telugu.
  • Some minor fixes.
Version 7.2.1.1 of VintaSoftImaging.NET SDK has been released.
  • Increased the performance of conversion from 1-bpp image to 24- or 32-bpp image.
  • Added the ability to cancel the RAW image decoding process.
  • Improved the algorithm that gets information about formats supported by (web) camera.
  • Optimized the memory usage and increased the performance when merging annotations with image.
  • Improved the algorithm for restoring damaged PDF documents.
  • Fixed the bug in decoding image-resource compressed with ZIP algorithm and predictor.
  • Optimized the memory usage at encoding large JPEG2000 images.
  • Fixed the bug in encoding JPEG2000 image with width or height more than 32768.
Version 7.2.2.1 of VintaSoftImaging.NET SDK has been released.
  • Added classes for managing changes (undo/redo) in object(s) (image, annotation collection, annotation, etc).
  • ImagingDemo has new code for managing changes (undo/redo) in images.
  • Fixed some bugs in the Sticky Note annotation.
  • AnnotationDemo now allows to manage changes (undo/redo) in images and annotations. Previous version of AnnotationDemo allowed to manage changes (undo/redo) in annotations only.
  • Fixed the bug in PDF decoder.
Version 7.2.3.1 of VintaSoftImaging.NET SDK has been released.
  • Added the ability to save/load images in DIB format.
  • Added new image processing command - HasCertainColorCommand, that checks whether an image contains a certain color.
  • Added the ability to save and load an embedded image annotation in TIFF file when annotations are stored in WANG packet.
  • Some minor fixes.
  • Increased the performance of text extraction from PDF documents with large TTF fonts.
  • Improved the algorithm of text extraction from PDF documents.
  • Fixed the bug in render of PDF pages.
  • Fixed the bug in parser of TTF fonts.
Version 7.2.4.1 of VintaSoftImaging.NET SDK has been released.
  • Improved the thumbnail rendering in WPF thumbnail viewer.
Version 7.2.5.1 of VintaSoftImaging.NET SDK has been released.
  • Increased the rendering performance of PDF pages containing JPEG2000 image-resources.
  • Fixed the bug in PDF page renderer.
Version 7.2.6.1 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in image viewer when image viewer is used in hidden MDI window.
  • Added the ability to monitor progress of PDF page rendering with ability to cancel PDF page rendering.
  • Increased the rendering performance for PDF pages which use tiling pattern.
  • Fixed the memory leak in Tesseract3.Vintasoft.x86.dll and Tesseract3.Vintasoft.x64.dll.
Version 7.2.6.3 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in transformer of text annotation.
Version 7.2.7.1 of VintaSoftImaging.NET SDK has been released.
  • Added the ability to render PDF pages progressively with ability to get intermediate image of PDF page with specified interval.
    Progressive rendering of PDF pages in image viewer can be enabled with the following code:
    imageViewer1.RenderingRequirements.SetRequirement("Pdf", new ImageSizeRenderingRequirement(0));
  • Added the ability to render PDF image-resources with JPEG2000 compression progressively.
  • Improved the parser of Type3 fonts.
Version 7.2.8.1 of VintaSoftImaging.NET SDK has been released.
  • Improved the parsing of TIFF files with JPEG compression.
  • Improved the algorithm for restoring of damaged PDF document.
  • Fixed the bug in parser of PDF document.
  • Fixed the bug in parser of TrueType fonts.
