recommendation for optimized configuration
quicoli
Post by quicoli » Tue Feb 18, 2014 4:33 am
Hi friends,
I'm using the following code to scan a A4 sheet into jpg file. The document is only a letter (full page). When using Gray Scale, the jpg generated gets 650kb. Is there a way to optimize this?
Thank you
            switch (opt.Colors)
                case Color.BW:
                    _device.PixelType = PixelType.BW;
                    _device.BitDepth = 1;
                    break;
                case Color.Gray:
                    _device.PixelType = PixelType.Gray;
                    break;
                case Color.Color:
                    _device.PixelType = PixelType.RGB;
                    break;
                default:
                    break;
           _device.AcquiredImages.JpegQuality = 80;
           _device.TransferMode = TransferMode.Memory;
           _device.UnitOfMeasure = UnitOfMeasure.Inches;
           _device.Resolution = new Resolution(200f, 200f);
           // custom area to scan are in centimeters, so, I convert it.
          _device.ImageLayout.Set(0, 0, (float)(opt.Size.Width / 2.54), (float)(opt.Size.Heigth / 2.54));
Re: recommendation for optimized configuration
Post by Alex » Tue Feb 18, 2014 4:09 pm
Hello Paulo,
Please try to save grayscale image as PNG or TIFF file, I think you will get better compression results.
