Version 8.0 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Wed Mar 05, 2014 4:33 pm
What's new in this version:
  • Added MicroPDF417 barcode support in reader and writer:
    • Implemented algorithm of automatic symbol size selection based on encoded data (with the ability to define number of columns).
    • Support for Macro05, Macro06, ReaderProgramming, LinkageToCompositeSymbol, LinkageToEANUCC flags.
    • Support for flags emulating Code 128 mode.
  • Added Code 32 barcode support in reader and writer.
  • Added ISO/IEC 15416 linear barcode print quality test for Code 32, MSI, Pharmacode, Telepen, Standard 2 of 5, RSS-14, RSS-14 Stacked, RSS Limited, RSS Expanded, RSS Expanded Stacked.
  • Some minor fixes and optimizations in barcode reader and barcode generator engine.
Version 8.0.0.5 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Mon Mar 24, 2014 1:57 pm
  • Improved recognition algorithm of Code128 barcodes.
  • Improved algorithm that calculates barcode defects in ISO/IEC 15416 linear barcode print quality test.
Version 8.0.0.7 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Wed Apr 09, 2014 4:27 pm
  • Added the ability to calculate or check the control digit for GS1 barcode with the following Application Identifiers: SSCC18(00), GTIN(01-02), GDTI(253), GSIN(402), (410-415), GRAI(8003), GSRN(8018).
Version 8.0.0.9 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Fri Apr 18, 2014 11:28 am
  • Fixed the bug in algorithm that reads data from region of 1-bpp image.
Version 8.0.0.11 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Thu Apr 24, 2014 1:46 pm
  • Improved the recognition of 1D barcodes with large size.
  • Improved the simultaneous recognition of MSI and 1D barcodes.
Version 8.0.1.1 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Tue Apr 29, 2014 3:25 pm
  • Improved the algorithm of DataMatrix barcode generator for compatibility with hardware barcode readers.
Version 8.0.1.3 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Thu May 22, 2014 1:22 pm
  • Improved the generator of DataMatrix barcodes.
  • Fixed the bug in decoder of PDF documents.
Version 8.0.1.5 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Tue Jun 03, 2014 11:27 am
  • Print quality test for 2D barcodes (ISO15415):
    • Fixed the bug in calculation of the FPD (Fixed Pattern Damage) parameter for QR and MicroQR barcodes.
    • Fixed the inaccuracy in calculation of the UEC (Unused Error Correction) parameter for 2D barcodes with more than 1 error correction block.
  • Fixed the bug in MaxiCode decoder.
Version 8.0.2.1 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Tue Jun 10, 2014 10:59 am
  • Increased the performance and decreased the memory usage when recognizing barcodes in image with a lot of noise.
Version 8.0.2.3 of VintaSoftBarcode.NET SDK has been released.
Post by Alex » Thu Jul 17, 2014 4:25 pm
  • In ISO 15416 print quality test fixed the bug, which occurs when image with small height (1 pixel) is analyzed.
  • Improved the reading quality of Postnet and Planet barcodes.
