Version 8.2 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu Apr 23, 2015 3:17 pm
We are proud to announce the release of new major version 8.2 of VintaSoft Imaging .NET SDK and the related Annotation, PDF, JBIG2, JPEG2000, Document Cleanup, OCR, DICOM Plug-ins and the brand new Forms Processing Plug-in.
  • Created a brand new VintaSoft Forms Processing .NET Plug-in, which provides the templates recognition, forms alignment and OMR (optical mark recognition).
  • Added the broad support for working with interactive PDF forms: Push button, Text, List Box, Combo Box, Check Box, Radio Button, Signature Field, Barcode Field.
  • Added the ability to sign PDF documents with digital signature and work with signatures.
  • Extended the list of supported web annotations.
  • Added the ability to transform the line-based web annotation by points.
  • In Web Annotation Demo is added the ability to change properties of web annotation using web property grid.
Version 8.2.1.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu May 14, 2015 2:10 pm
  • Fixed not citical bug in JPEG decoder.
  • Improved algorithm that restores damaged PDF documents.
  • Improved algorithm that generates appearance of Link annotation.
  • Fixed not critical bug in decoder of image-resources.
Version 8.2.2.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri Jun 26, 2015 10:25 pm
  • Added the ability to rotate JPEG image orthogonally without quality loss (only if image width is multiple of 16).
  • Some minor fixes.
  • Fixed bug in parser of PDF page.
  • Fixed bug in extraction of formatted text from PDF page.
Version 8.2.3.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Jul 07, 2015 4:32 pm
  • Many improvements in web image viewer.
  • Many improvements in web thumbnail viewer.
  • Added the ability to use touch input for editing annotations in web annotation viewer.
  • Many minor fixes in web controls.
  • Improved the user interface of all web demo applications.
Version 8.2.4.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Jul 29, 2015 2:55 pm
  • Added ability to override search algorithm of CID fonts and use custom CID font instead of CID font from PDF document if CID font from PDF document is not found.
  • Added support of OpenType fonts.
Version 8.2.5.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Aug 18, 2015 5:14 pm
  • SDK was successfully tested in Windows 10 and Visual Studio 2015.
  • Increased the performance of web viewers when web viewers is used for previewing “big” multipage files (500 and more pages).
  • Fixed minor bug in TIFF decoder.
  • Increased the rendering speed of PDF documents which contain image-resources with big JPEG images.
  • Added progressive rendering of image-resources with progressive JPEG images in PDF documents.
Version 8.2.6.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Sep 09, 2015 3:50 pm
  • In WpfImagePrintManager class added the ability to process image before printing. This can be useful if color image is printed on black-white printer.
  • In WpfImagePrintManager class added the ability to print image with resolution different from printer resolution. This can be useful if printer has very high resolution.
  • Fixed not critical memory leak that may occur only if application loads lots of annotations.
  • Improved the algorithm that extract text from PDF document.
  • Improved the algorithm that restores damaged PDF documents.
  • Fixed minor regress in PDF renderer.
  • Fixed minor bug that occurred when rotated PDF annotations merged with content of PDF page.
Version 8.2.7.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu Sep 24, 2015 5:24 pm
Version 8.2.7.3 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in decoder of TIFF files.
  • Fixed the bug in parser of PDF documents.
  • Fixed the bug in algorithm that extract text from PDF page.
  • Fixed the bug which may occur during text recognition in large images with noise.
Version 8.2.8.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Sep 29, 2015 2:42 pm
  • Fixed the bug in PDF page renderer.
Version 8.2.9.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Oct 07, 2015 11:29 am
